jd6820
I've read into this as was unsure myself. Here is a link to the document used by the DVSA to inspect trailers and the guidelines they follow.
https://assets.publishing.service.g...hicle-approval-inspection-manual-trailers.pdf
It would seem that as typical 3500kg trailers are not 'semi-trailers' i.e. not designed to impose a significant load onto the towing vehicle then the maximum weight the trailer can be is the plated GVW as stated on the plate unless this figure is not given in which case the maximum axle weights are used, which usually add up to make the GVW.
A semi-trailer appears to have lets say a GVW of 41000kgs and this is made up of three axles rated to 9000kgs AND an imposed load rating of 14000kgs. Which doesn't appear to be the same as balanced trailers such as Ifor's?
Now, the real question is are they gonna get you to unhook a trailer to prove it's overweight when you have just rolled the towing vehicle off the bridge to get the trailer axle weights and the trailer alone is 3500kgs but imposing a load on the towing vehicle? I'd say not as long as the rest of the outfit is below the allowable GTW. However, they would assume some load is being imposed and probably argue that the trailer was only designed with it's own 3500kg GVW and is overweight just like you can't exceed your cars GVW without potential of being fined.
