Mogmans creations 🤔
The alternator is connected directly to the fan in a cowling so not as simple🤔 but not had a proper look if another one can be fitted🤔
this is what the engine looks like only a 4 cylinder
Longer belt and a bracket to fit alternator. Just need to move bonnet back a further 6 inch again 🤣🤣 or cut a hole in it for alternator to poke through 😜
tha's the fuel pump you can see, I think ...... alternator's in the fan hub is it @Mogman
Yes you can just see the back of the alternator if you remove the side cowling may have a proper delve tomorrow if I get time
as for spending money on it I have a very tight budget basically the trailer it came on is going to fund it so stuck it on the bay to see what happens
Left hooker
Left hooker
You can jump start a 12v vehicle from a 24 volt one so you can run your 12v dash from battery's and have 2 switches one for dash and one for starting
diggerjones
diggerjones
Can you still ask questions on ebay?
How much for the digger!😂
Can the starter not be reworked to spin the same speed on 12V ?
You appeared on insta tonight mate
That’s a long time ago😳 Sean’s machine I think, never did have a play on it though😢
but back to the job in hand🤔 now I thought the Perkins was a tight fit😳 this fecking think is massive compared to it🤪, had to leave 2 bolts out of the bell housing (still 8 left though😉) to clear the hydraulic oil tank🤫
but made a bit of room the other end by cutting the radiator in half😳 only need the oil cooler part👍
hope the starter doesnt let me down as their is no way that’s coming out without a fight
I’ve had to leave this full 2” gap😯 so the engine can be inserted and removed (hope it’s not coming out again😳)
Now I removed this engine about 3 years ago (nearly sold it a couple of weeks ago) and hasn’t been started since then but stuck my booster pack on and it went first touch (thank gawd 👍) so well pleased with it so far😉
just need to wire it up to the dash and fit a new battery tray, the exhaust and air filter will need a bit of adapting again but in the main 👍
No not really, I like a challenge😳 and with all this talk of what 5 tonners can and can’t lift thought I’d better up my game a bit to get my scrap 4.5 tonner to out lift the lot of them😂😂
trouble is it’s not going to look stock with this lump in as the engine is a lot bigger😳
I’ve had to do this today
yes cut the whole back end off😩
Erm you can’t come anymore it’s going to weigh in at 10 tons and have 20tonner lift rams on it by times your done 🤪
New project for you. 😜
What a pile of crap I’d be embarrassed to take it as scrap on my trailer😳 would have to go in a curtainsider to save face😂😂
So onto today’s disaster dropped a piece angle iron out of the vice which caught the handle of my mug and took it clean off which then dropped on the floor and shattered😢
So had to improvise
the angle iron was to make another battery ‘box’ as need two now to start the engine managed to ‘find’ a small car battery which holds a charge and a place on the machine which won’t interfere with the cooling
thought I’d show an interior shot😉 quite tidy inside🤔 shame it’s going to get covered in broken glass soon😢😢
and finally it’s alive again👍👍 tracked it out from under me shed on tick over result😉 (the Perkins needed to be flat out to move and would still pull the engine down to a stall) and without a whiff of smoke👍
Just stuck the corner weights on to see what I’m up against to ’fill the gap’
diggerjones
diggerjones
Is it sold. What budget have you got to spend on the glass?😁
Yes sold it today👍 It’s going to need retracking soon as one of the steel inserts is escaping so keeping an eye out for some steel tracks the wider the better👍 would like 5-600 wide
Slacken the tracks off a bit you'll get a bit longer out of them 🤣
