"Yeah they had to cut couple women down out of trees"
I'd have just cut the trees down .... they'd have soon abandoned their posts :ROFLMAO:
Thomas7740
Thomas7740
Pissy day digging around services, then piping and stoning up. Priced job so have little brother out loading stones with ex30 and driving dumper to allow me to craic on piping etc
'little' highways job again this week,road closure Friday night,not your usual cones,barrier wagon couple blokes in transit style........4m high fencing,concrete blocks,razor wire,double gates,literally hundreds of security ranging from checking passes to full on ninja paramilitary goons,protestors evicted by sat morning then 24/7 fence erection to ensure positively no chance of anyone inhabiting verge again.Was here last year when security stopped mates wagon turning right into site,while he was sitting in road protestors jumped into hydrema on trailer,road closed three hours until they were 'talked out',have walked down pavement when road open not nice,busy road with conc yard n skip yard round corner
And we wonder why all the infrastructure work in this country is so costly 😂
Hey dont be ageist....... I remember thinking fifties was ancient 😬
Me too ...... 63 was well old ..... an' damn me now I'm there :oops: didn't seem to take long either :cry:
Been digging trenches for a new pharmacy, all clay, all wet and sticky so like an ice-rink then to top it off Lqnd drains running through it and having to shore it up as its dug out
Everythings relative I supose 🤷‍♂️
Moved to france when i was 35 and thought I was old then.... only now I realise its not 😁
Took delivery of this from Aidan @CPS today.
Had a quick play around fitting flat faces, and with pipe routing.
Thanks Aiden 👍
nice looking bucket that ...... gonna have to make me one of these scandy graders :giggle:
Looks good in the photo (y)I have similar scandi design coming from BMC - if it ever gets here ..been stuck on a pallet since Dec due to Brexit :mad: TBH the pipes are a PITA but they still have their place if you dont want to go the tilt hitch or tiltrotator route on that particular machine, I often tidy our way out of a job with the 3t and they save a lot of screwing around.
Dont know if you have problems cracking the pressure off on that machine ... it was a bastard on the 8t so bought some of these.
Are you on a roller or pedal with it ?
Thanks Aiden 👍
Suns out and it feels like spring today ......getting organised for the first tank of the year and its a lump - going in in rock 🤨
Wont be digging the hole with the u17 thankfully 😁
View attachment 22556View attachment 22557
we had that yesterday afternoon ... was glorious and almost shirt-sleeve temp.s ..... Clara all day so sod all done though, unfortunately ... today is a different story .... blowing like ****, threatening rain at any moment and a good 10 deg.s C colder :(:(
was so nice to have the sun on yer back though ........ not seen it in weeks
I`m on a pedal unfortunately, there`s no flow control on this duckling, but there is adjusters on the pedal plungers, so may have a play adjusting them so they don`t open as much and slow it down.
We do some work for the LA. a lot on rural lanes, with a fair crown to them. with the 3cx easy to adjust to the camber, hopefully this should address this, with the duck.
It`s not normally to bad taking the pipes on/off, but we`ll give it a try, I may get a set of coupling pliers if we find we`re struggling.
can always put a restrictor in one of the lines ... replace an adaptor with a throttled item or get a blanked one and drill it out a mil at a time 'til you find a sweet spot .... a lot of rotators have a throttled adaptor in the one port -- often just a 1 or 1.5mm hole, which slows oil delivery massively ... and as it's not a continuous flow, shouldn't give you too many issues with heat build up Search | Flowfit (flowfitonline.com)
or put an adjustable flow restrictor in the circuit -- either an inline jobbie or a lever op. Hydraulic Flow Control and Flow Divider Valves | Flowfit (flowfitonline.com)
Yep unfortunately mine is going to be off a pedal on the old KX71 so may well have the same issue........ on va voir (y)
