Yes the pan of water . I think 2 faulty stats is unlikely . It has a rubber seal that fits to the rim of the stat and it’s sandwiched between the thermostat housing and lid . It looked like a good fit . The original seal was cracked and perished though and could of well let coolant by . The new one seemed to go together nicely .assume you're talking the pan of water ??
you really do need to get a thermometer in it to check opening temperature accurately .... if it's opening early it'll never warm up in winter ...... but as said the new one was no better ??
what's the seat like in the thermostat housing ... not able to allow any bypass flow??? / corroded away anywhere?? / clamping the thermostat in place firmly ??
