using DC injection, I'd be worried about snapping the motor spindle TBH, with the kinetic in the bladeYou think a saw like that could be stopped dead with a device like in that video?!
right gentlemen ...... I am in need of your collective knowledge/experience .... maybe best guesses.
tripped over this pic today ......
this is the valve that controls the 'Drema's throttle .. this ain't mine but is identical off another Hydrema.
I have five levels of 'volume ' ..... Idle 1000rpm, standby 1400 rpm, low 1800 rpm, medium 2000 rpm and high 2300 rpm, all button controlled.
she auto idles after 10 seconds inactivity and I pre-select what 'volume ' I need on start up(or at any time I like after that)
if you can't make it out on the pic..top pipe is labelled L and the port below it is labelled P
I'm guessing the 'goldy' coloured bit next to L is a solenoid and there're 4 wires going into the other bit from the multi plug ... as far as I recall and can see here
Anyone ever seen one of these before, or got any ideas how it works ????.... it basically varies the stroke of what must be a cylinder which pushes the throttle cable and opens the injector pump up to give it the beans
I surmise that P bleeds pressure as required, from the LS line, when it senses a demand for 'action'
(I'll have to see if I can see WTF it comes from on mine), which is in no where near as convenient a position, to examine (tucked down/under/beside the Deutz's sump), as this one is - hence grabbing the pic ....
but quite how much travel to give the throttle must be determined by those wires, which presumably are the four separate switches on the dash - SB, L, M & H
also guessing the 'goldy' coloured item is responsible for dumping said pressure for auto idle to occur ??
Some kind of proportional stepper solenoid perhaps?
If this ever goes wrong it's gonna get a cable - end of, but would be nice to know HTF it works and whether anyone has any idea WTF this 'valve' is called ???
plus of course how it functions
Game on fellas .......![]()
she doesn't rev on start up Smiffy ?Dont really have a clue but would it not make more sense if pressurised is idle taking a supply off the return to tank or pump to block otherwise each line would need to have a pressure sensor
Also some machines of that age rev up when the engine starts and quickly die off i presume as pressure is reached in the auto idle circuit
Just my thoughts though
had a very similar response from another guy on the P&C forum ScoffThe 4 wires come from what must be a large potentiometer,haven't a clue what one would be called.
Oooo, I like that @V8Druid , looks quite well built for a kit? Where did you get it from?had considered making one, but couldn't for the price of this .... and having the dry time to do it.
here you go Charlie .....Oooo, I like that @V8Druid , looks quite well built for a kit? Where did you get it from?
Cheers, C.
Here my swing
I was considering something like a 300 square slab under each leg .. and may well yet do it, but for now they seem to be sitting quite well and've not sunk barely at allDad and me made our swing for my wee one outa a couple of scaffold tubes ,and put the legs on a wee flag each to stop it disappearing into the garden. Our one could spent hours on it
(If you can't make it outa scrap, it's not worth making!!)
