R.Sanders Plant
Test sent, breakfast and my new dumper 😍
2 tonner for comparison.
It's a pretty pig... Few tweaks needed when I get time. But for the moment it can take over whilst I transplant a 3 pot into the 2t.... The Petter has seen better days and is gutless 😟 will put the electric start kit on another ph2 that is in my stothard Pitt.
L
Lynchy
1.3.7. Risks related to moving parts
The moving parts of machinery must be designed and constructed in such a way as to prevent risks of contact which could lead to accidents or must, where risks persist, be fitted with guards or protective devices.
Pretty sure written down rules don’t apply in the West Country as nobody can read....
Guarding is a future project along with relocation of a few controls.
But the risks do not exist as there is no one near the belting whilst in operation. (y) No point guarding it until I'm happy with it.
L
Lynchy
'no point guarding it.......till your happy with it?seriously that's utter bull s**t,no one ever 'intended' to get caught in a drive belt,seen your posts on both forums for years n reckon you do pretty good but having worked in plant,quarrys Inc management since leaving school,in the bad old non existent HSE days that so many seem to view through rose tinted lenses ,nearly having been killed at work myself ,please take the small amount of time,guard the drive flywheel n head drum drive
So spend a lot of time, money and effort fitting a proper guard.... then cut it off when it does'nt suit, or bodge some mesh on without any real consideration for it and then wonder why it's caused a accident further down the line.
I always guard things, Our Stothard and Pitt Roller is a prime example. But its simply not worth doing until I've worked out any issues with the setup as it's scratch built.
Crusher is very close to having catwalks added and guarding, BUT one thing that has become evident is that the belts are too long and could benefit from being a good bit shorter to allow more adjustment for wear. Whilst it's not going to affect the guarding design substantially changes like this are why I'm running it up to see what flaws there are before things get finalised.
The conveyor is a different matter entirely and was only brought a few weeks ago with today being the first run up. Bottom line is it needs a Electric Motor rather than the Honda 13hp engine as IMHO it's not suitable nor safe for the application and cannot be stopped quickly in a emergency (I like Line pull E stops for belts! simple and effective right along the length).
I appreciate what your saying, but its the same as a PTO shaft.... All the guarding in the world won't save you from stupidity! best bet is to keep f****ng clear of it when it's in motion! Likewise throwing a bit of mesh over it in a half arsed manner and exclaiming that it's "guarded" is worse than no guard at all in my book! Better to get it tested for half a day and then make something that is properly up to the Job!
diggerjones
diggerjones
I'm not commenting. If rory has a guard or not.
Think it was fred dibner or Johnny cash that said about a massive spinning circular saw. "You don't need a sign to tell me not to tough that"
Or don't put your fingers where you wouldn't put your knob😃
As long as you are the one doing the work I understand where you are coming from. Just don’t use an employee to test it out!!
