Or change the Hydrama to mineral oil?!..................
that's not a bad idea Mike ..... funnily enough, was only cursing myself this morning, for not keeping some of the 12/24V pumps I used to have sat about, for similar sort of thoughtsCould it be an option to fit an independent tank/pump setup powered by a battery similar to the setup you get on an ifor Williams tipper, either with a leisure battery fitted or an Anderson plug connection for powering from prime mover. The hydraulics could have a tee to be driven directly from other equipment like dumper or jake but when on hydrema could be donkey pump to get her up.
now YOU are really trying to wind me upOr change the Hydrama to mineral oil?!..................
yeh, correct ... prob.s in excess of 600+ ltrs .... but I still have to put the bio somewhere, plus all the flushes ... and TBH I'd be well worried about all the seals, pipes, etc. .... it's only ever had bio in in it ..... for the grief, I'll stick with itI thought you said you had a bit of 32 knocking around.... It’d be fine for flushing, and you wouldn’t need to fill the reservoir right up whilst flushing either. A mere few hundred litres/quid and you could turn your back on all of the issues/hurdles/headaches imposed upon you by that ‘environmentally friendly’ shite that came with your prime mover!
THAT is real interesting idea Rob .... no need for any connections/ plumbing/re-plumbing of any descriptionDruid,
Taking the idea of a separate onboard pump one step further, how about using a small engine to drive the pump?
You can get two channel remote controls on eBay for only a few quid. They are like garage door openers. If you use a two channel one the first channel would be to start the engine and the second for lift and lower.
A bit of work to build but once in use would be ‘simples’ and you could tow it with any vehicle of your choice, even the P38
Rob
Is the ‘drema 12 or 24v? What about a transit tipper type setup mounted in the chassis and just an Anderson plug cable connection for power.
24 volts Pettsy .....Is the ‘drema 12 or 24v? What about a transit tipper type setup mounted in the chassis and just an Anderson plug cable connection for power.
Yep this sounds like just the ticket. I suppose you have to weigh up what you plan to do with this kert.I think with the size of the trailer, and the size of your machine, I’d just spin your bucket and a couple of pushes and the load will be out.
either that or just leave the ram unpinned, unless I want to hydraulically tip it Oll .. pin comes in and out easy enough and have stuck a lynch in the one side ..... replaced the nipple in it today too, so can keep it lubedI think with the size of the trailer, and the size of your machine, I’d just spin your bucket and a couple of pushes and the load will be out.
Yeh, the trailer I have at the moment isn’t a tipping one and all I do is drop the sides down, couple of minutes tops and it’s empty and this trailer is over twice the size of my old one.Yep this sounds like just the ticket. I suppose you have to weigh up what you plan to do with this kert.
forgot to say that unlike you, I don't always have my VA-r on the dipperI think with the size of the trailer, and the size of your machine, I’d just spin your bucket and a couple of pushes and the load will be out.
That’s perfect Gra, did mention something like that earlier on, but just been able to do it from the side of the trailer rather than having to crawl underneath each time, that way at least you get to fabricate somethingeither that or just leave the ram unpinned, unless I want to hydraulically tip it Oll .. pin comes in and out easy enough and have stuck a lynch in the one side ..... replaced the nipple in it today too, so can keep it lubed
You can always push it away from youforgot to say that unlike you, I don't always have my VA-r on the dipper![]()
