K
Komatsu
Really enjoying reading thisOK ... fresh set of pix quota ...
having checked the pivot holes with the vernier, they were all pretty much on the 32mm mark .... 'cept for the middle bits of the pins themselves, which appeared to have taken all the wear ... miraculously - so found some 32 mm bar ... of which I had very little ... this was a ring rolling mandrel I used to use in me lathe for rolling a length of rings from a length of bar ... but was me only piece so it had to have it ...
drive tag came off and it became a 'length of 32 mm again..... for some new pins ... after I'd gotten the remnants of the one lil' sod out of course
flushed the one end off with a 9" thin disc ....
but still wouldn't have it with me one hand-er and drift .....
.......might've with someone holding the drift, but wasn't happening so ...... split the lugs with the 9"
and out they came, with a bit of slogging ...
the offending item's constituent parts
note the worn centre portion
ran a weld across the top of the slits ... only need to stop 'em opening up ... lopped up some new pins and made a couple of retainers ... stop 'em going round in't holes ... summat a little more substantial'd 've been good, but sod all to handthey'll do for now
couple of grease nipples in the moving parts ......
and hopefully they'll be good for a few more years
also sorted the wiring out this morning and got that all secured and re-routed ... and have been pratting about with some mod.s to that for an hour or so before tea and had a bit of a go at the brake linkages and compensator ... which wasn't co-operating at all, so soaking in WD for the night ... day just seemed to evaporate ... but've made decent progress and the body's about ready to get stuck back on .... the ali primer makes a decent top coat too ... lasts for years on everything I've ever used it on - like me trailers ... only ever had two coats ..... and now it is time for me bed![]()
