Mulholland plant hire (northern Ireland)
Jimoz
I don't think I have ever seen drawings that haven't had steps and thickenings and widenings. Fairly standard to have window sampling or plate bearing tests or even just trial holes dug before a foundation design. Plus plate bearing tests and engineers design for the crane pad to lift the timber frame in.
Im guessing your work is bigger sites or more expensive builds than I'm used to?!
Not when I was doing house building work.
It was small developments from 1-5houses. With plot values from £350k - £1.2m
So real variety of stuff.
It was the crane companies asking for the crane pads being designed aswell.
And if you get into temporary works stuff then it's quite plane that you have to have an engineers design
crane pad!!! .. could only ever dream of one of those on a site :rolleyes:
groundworker
groundworker
Those are massive jobs by my standards! Big enough to pay for proper designs anyway
I've poured loads of foundations with no details at all, doing basic extensions usually with just a plan drawing.
It used to be that every council had their own rules based on local ground conditions, usually 1m - 1.2 deep, 450 wide single storey, 600 double. All sorted verbally with BC.
Quite rare to find that now though
Seen a photo yesterday in Scandinavia crane leg went through an underground tank!
my last year in school, Celtic cranes had 1564 Grove in the grounds moving some portaclassrooms ... put a leg straight through the boiler room ducting carrying all the hot water piping to the main building .... was lucky he'd just taken the bite and cabin just sat back on its pads --- change of underwear moment for the op. though :ROFLMAO::ROFLMAO:
Above ended up horizontal
bobthebuilder
Our bc is still like that on extensions etc ,but the ground here is good
The term ‘southern fairies’ comes to mind 🤦‍♂️😂
If that's in reference to me, it's not so much being soft. It's more disposal of liability. If someone's fresh plaster cracks from settlement they will be trying to take you to court the next day.
We are on clay for the most part so now alot of projects are getting piled. I was on one block of flats in Croydon and between arguments with the structural engineer and the Q,S they piled half the block and the other half was on strip foundations where the soil sampling had detected a seam of hard ground across the site.
Yep, all a building control officer does is check what youve done is to what the design says. They won't make suggestions or tell you to do x y or z, it's literally yes that passes to what the drawing says.
Gone are the days when they'd say 'do this' and it'll be right.
The one I use does 🤣 To be fair he was a builder before going into the regulations side so has seen a bit.
