'Twas a wild night here, last might .. God knows what the West coast of Paddyland was like .... had a horrendous forecast, according to the box.. bad enough here!!
Pam
on a mission this morning .. headed for town .. in Crimbo mode
... 'least I wasn't involved, other than the list I got left for this morning's adventures.
Bloody twinkly lights !!
Clara does love 'em though
.. Four inches of water back in the fish pond .... as I said was some wild night
and sort a few other bits an' bobs ........ and I was sorted ...
Time for some oil extraction ....
tha's one side of the cylinder closed up tight as ... plumbing off to the port and drained, blown out and refitted ... not a lot in it thankfully ... then on to t'other ...
not much in here either
... pipes blown through and the ports
.... couldn't have been a lot left anywhere ...
sorted some FF males and got 'em screwed on to the pipe ends, then quietly fed it some Plantohyd .... this is 61.5" full open ..
surprised the ports're only 3/8" on it
... half would've been a better bet IMHDO ... but it gets there ..
glad I added the extra inch to the one pair of legs on the adapter ... would've been too close for comfort without it ... if not too tight
hose lengths were fine, fully crowded and open, but closed and extended out was a different matter .... another 12" needed .... so found meself some 18", half inchers ... which annoyingly were BSP/metric, but luckily had some suitable 1/2"BSP/metric adapters and it all went together nicely ...
with plenty of tolerance to thread 'em through me 'carrier' rings ....
gonna have to watch they do not get snagged on those protruding pins though
... couple more rings might be on the cards to be sure
Will have to have a look another day .... Pam back and wanting to do me treatment, as we'd left it this morning, in deference to her
'mission'.
so left the SEC on and dropped the 'Drema out on her parking block, found another for the SEC ....
...... and scuttled off indoors, after a major square up, for some more plumbing ..... of a different kind .... in me arm !!
.......But not before doing this one for you lot ...
shuts with a hell of a 'CLACK'
... You'd deffo not want to have anything you value in there
... and that's on 180 bar, on me rotate line
need to acquire a check valve for the closure port .... from my experiences with me Cranab, these things tend to 'let go' quietly without a check in the circuit, at the port.
Interestingly when I ran her up this afternoon, everything on the dash worked perfectly
... the odd temperamental switch (which're always annoying) performed faultlessly
.... but
more annoyingly, the auto throttle settings seem to have got their head in a knot
... will have to put the tacho on it and see what's what .....idle is well low and the first
'S' throttle setting (1400rpm) is too .... hence the low(er then usual) throttle setting in the vid
...... curiously the
'L' setting (1800rpm) sounded about right to my ear
... Summat's either gone out of adjustment .. or summat
stuck isn't any more ??
