Best way to remove footing?
Stubota86
Stubota86
i would think just a strip found so may not be to bad to break out just back fill the area you need to start on and so no straddling trenches and break out and dig down to the new level as you go if the first builder was too tight to dig to correct (minimum 1 m deep subject to building control )in the first place the concrete may not be the best any way
very true
I was chatting to an inspector once who looked at a dig, signed it off and left. Realised he’d forgotten something so popped back and found them mixing up ballast and cement in the trenches. Made them bucket it all out and stayed there all day whilst they did it properly 😬
A
Arduainefs
Presume the found is reinforced? 800 is a deep ol foundation so think you will need a bigger machine. You can be a s careful as you can but taking that lot out the trench is going to be a lot wider im afraid:oops:
Sounds like an expensive cock up by someone!!
Simon edwards
Simon edwards
We bought a Tekna from dr pecker with a dual pin set up for our 1.7 ton cat 2.7 kubota.does’nt get loads of use but is invaluable when needed,impressive little breaker and it was an ex demo model ,very reasonably priced and as new.
???? does that have two points ??? or two differing mounts :confused::confused::unsure: ..... I assume the latter .... having thought about it :giggle:
Be a third pin position on the headstock to suit both machines....
Just FYI Dr Pecker (attachment Solutions Ltd) are the only firm (whose product I have broken) that have without quibble stood by and rectified the issue! Never had it before and likely never will again. But they are spot on!
A
AusDave
If there's a lot of steel in the concrete I'd be having second thoughts. You won't get anything but tennis ball sized bits of concrete off it if it's well reinforced, and it will take ages and cost more than you think. Not to mention wear and tear and the moil jammed in the steel.
Russell
They ripped out a load of footings on a local school that's being re built. I didn't see them do it but they had a couple diggers minimum 20 tonne. Bloody great 3 meter long bits on the pile.
Aparently this footing crumbled after being hit with a sledgehammer. No rebar either.
Fingers crossed the ripper will handle most of it after the pecker makes a way in. It's day rate anyway. It's only 9m total.
small quantity of bang .... strategically placed 😂 (y)
😂 😂 :ROFLMAO: :ROFLMAO: :ROFLMAO: but you gotsta make a big enough hole first for that regime :unsure:o_O:oops:
A freind may of totalled a 9" block wall with stitch drilling, crow bangs and some heating oil soaked string 😂 His excuse was it was easier than the sledge
I got a mate totaled a 9" wall too ..... bout 50 feet of it ...... with a yammy RD400 :oops: o_O :ROFLMAO: :ROFLMAO: :ROFLMAO: and walked away from it :unsure:🤪
Jimbo69
Jimbo69
Shouldn’t put up much of a fight then. Can you take some pictures when you’re doing it? It sounds like something special 🙈
Rob65
No Druid, large quantity of bang and you get broken concrete and an empty trench all in one go😀
Joking aside there are several low explosive products on the market that are great at breaking stuff like this up without vibration or ‘fly rock’ . Not a lot of cop in heavily reinforced concrete though. 600 wide, 800 deep by 9m long would all be out I a day.
Do a google search for Nonex if you want to know more.
Rob
Rob
Reading with Glee
Rob65
