Even nicer if he had a shed to work from
1715080599326.png:ROFLMAO::ROFLMAO:
Diggerdavey
You have done some work there!
absolutely ... and that's just Pam's side of the trellis fence ... dug a couple of thousand tonnes out on the other side to create me patch :rolleyes:
rocks started to 'outgun' the JakieB and a 'duck hunt started ... but in the meantime the landscaping got done
13-10-11.jpg IMG_3212.jpg 16-10-11 (3).jpg 2012-08-03 12.28.40.jpg 2012-08-03 12.28.55.jpg 2012-08-08 16.30.23.jpg the last block :giggle:
learning to lay them 9" hollows was an 'uphill' learning curve :LOL: .. had the drop on it after 1200 of 'em though :giggle:;)
lots of digging later
and I eventually had me 'patch'
View attachment 60943 View attachment 60944
View attachment 60945 View attachment 60946
View attachment 60943 View attachment 60955 View attachment 60944 View attachment 60949 View attachment 60950 View attachment 60951 the last block :giggle:
View attachment 60956 View attachment 60957
Nice 40' container on casters not a fixed structure, move it back and fore 2" every year
so carrying on from the Countax I got given ... have managed to find some dry hours to play about with it ... 's never gonna mow again for sure .. ripped this out from under it .. might salvage a few spare bits off it, but deck is fooked.
spent a bit of time investigating all the bodged wiring and concluded it was gonna be a re-wire it job , so gutted out all but the bare essentials - hoping Angus @modelman093 can tell me WTF the connection is below in the second pic?
guessing it's either a kill of some sort, or possibly temp./oil sensor ... assume t'other is a charge regulator as it's direct to the battery supply at the solenoid?... carb.'s been stripped and cleaned and fuel cut off solenoid at the bottom of the float chamber ain't clicking so assume seized, so wedged that in the open position and'll put a tap in the fuel line ('s possible that it's also used as a kill as it blocks the main jet in the closed position - Angus'll know for sure), but not looked for info. on these yet .....
couldn't get it to turn over as the electromagnetic clutch driving the deck is seized solid so needed to get it up in the air a bit... so woke the 'Drema from her slumbers and popped it on the bench
removed all the extraneous crud that was never gonna get used again, so' I could get at the clutch better and removed what I could of it ... the main body was a different story .. left this dogged as hard as I could get it overnight with plenty of WD soaking
still solid this morning, so it had to have it :giggle:
the thin disc, that is :LOL:
crank now goes round sweet as and we have compression (y):giggle: finished removing all the un-necessary cr*p that this was not gonna need in its new life as a garden tug and sat it back down on the deck ... as it started to rain a bit heavier :(
will see about making it run next, with some new basic wiring, minus all its kill switches/knockouts/lockouts/etc. .. fully stripped down for racing :LOL::ROFLMAO:
Vicki arrived late afternoon for me to take a look at her wheel .... lucky girl, rim looks fine - two new tyres ordered for tomorrow ... bang a pair on the front and keep the good one to go on the rim I bought Sunday, for her to chuck in the boot if she's going anywhere distant ... off to Manchester next week on a McGuire course she teaches at .... so keep yer phone on standby Paul @Mogman :ROFLMAO:
fair play to Ruben @doobin he said he'd have been and sorted her Sunday, but he was away sadly. Fortunately that full size 'supposed' space saver came home sweet as ... never seen the road before, looking at it this afters :rolleyes:
did knock these out over the weekend - Pam wants a towel rail ... usually hang 'em on the cooker oven door handles but ain't keen on doing that to her 'new' Stove ...
just got to assemble em .. CBA to get the Caddy out for four little welds - will have to wait 'til I have a few other things that need the hot stick - like a tow bar for the new tug and anything else I can think of:rolleyes:;)
oh and this got a bit closer to the bench this afters too :giggle: ... While I had the 'Drema running :rolleyes:😁
still in need of a sheave though :rolleyes: .. no one got one hanging about?? :unsure: .. have to ask Russ - see if he has anything sat about? 🤞.. everything else'll need designing around it 😙🙄
the wonky looking bolt in front of the Tico is out of the 'Drema's fuel filter mount bracket .. head snapped off again - third one I've had to replace ... bracket has a nasty wobble, ticking over, even though it's made of 8mm plate and bolted solidly to the side of the engine block 😞 .. spotted it when I lifted the bonnet to turn the isolator on :rolleyes:
weather is 'sposed to be a lot better tomorrow :cool: .... for a week :giggle::giggle:
didnt realise your neighbours were that close
sadly yes -- the miserable pair too .. nice ones're next door to them -- pity wasn't the other way round :cry: .. one plus side is we're a fair bit higher/elevated above them a good fifteen-twenty feet or so :giggle:
View attachment 60971 View attachment 60972
View attachment 60970 View attachment 60973
View attachment 60966 View attachment 60965
View attachment 60983 View attachment 60982
I think iirc it's a suppressor to reduce interference on your neighbours telly .
Now then...time to have some fun play about with pulley sizes that thing will fly 😊
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::giggle:
(y)(y):giggle::giggle::giggle: ... bear in mind the brake is a 60mm disc :oops:, with an even smaller brake pad :oops: :ROFLMAO: ... not sure the hydrostatic box'd stick too much in the way of increased rev input ... 'specially as this one doesn't have a fan to cool it:unsure: ... but i like your thought process though :giggle::love:
Pretty sure it's the Reg/Rectifier - two yellow are AC, red is positive and the case is ground.
Remember it's on the input to the gearbox, so high speed, low torque.
The braking effect is multiplied through the gearbox.
Now looks like a tin pot industrial estate and part time scrap collectors yard!! Must of knocked several hundreds of thousands of whatever the welsh use as currency off the neighbors!!
Do wonder one of them is pi55ed off!
The over one can’t even afford mains water any more!!
the brake disc has it's own separate shaft out of the gearbox on these things, but yeh will be much slower than the input
what you can't see is that there were 17 dumpies of stone in that aerial, 4 or 5 bags of 20 to dust and a couple of sand ... 's all stacked up along side of the drive now, in what we in Wales call 'A Wall' :p:ROFLMAO::ROFLMAO:
WP_20201210_09_44_03_Pro.jpg WP_20210102_16_04_17_Pro.jpg WP_20210919_20_58_47_Pro.jpg WP_20210514_17_09_23_Pro.jpg ;):):giggle::ROFLMAO:
well I'm getting closer with it :giggle:
created a new loom and re-wired it this morning...
the mystery terminal Gavin, was as I thought, - a kill line -- had the fan cowl off this morning and it's connected to the twin coils to earth 'em out.
Ignition switch took a bit of sussing .. interesting set up ... has a set of kill terminals, permanently connected when off, open circuit in run position.
So set them up to ground that kill terminal - float chamber solenoid's on the run circuit, starter solenoid on the crank position .. works fine have had it firing on carb cleaner (y)
Poor old spark though .. gonna have to have the coils off and clean their faces off - got the flywheel 90% better than found, but guessing the coil's faces're rusty too and 'screwing up' the air gap.:(
WP_20240529_14_06_53_Pro.jpg WP_20240529_14_06_44_Pro.jpg WP_20240529_14_07_06_Pro.jpg amazing how much gear you need out for a piddly little job like a re-wire :rolleyes:
tyres stopped play after lunch - went and got Vicki's motor sorted -- rim was fine when the tyre came off .. put a pair on the front and the O/S/F can go on the spare rim I bought Sunday, when it arrives - another DHL saga BTLs :mad:
'sposed to have arrived this morning - no ****ing show - email saying ''unavoidably delayed" .. Twunts 🤬
oooops ..... forgot to hit post last night :rolleyes::unsure:
