so carrying on from the Countax I got given ... have managed to find some dry hours to play about with it ... 's never gonna mow again for sure .. ripped this out from under it .. might salvage a few spare bits off it, but deck is fooked.
View attachment 60971 View attachment 60972
spent a bit of time investigating all the bodged wiring and concluded it was gonna be a re-wire it job , so gutted out all but the bare essentials - hoping Angus
@modelman093 can tell me WTF the connection is below in the second pic?
guessing it's either a kill of some sort, or possibly temp./oil sensor ... assume t'other is a charge regulator as it's direct to the battery supply at the solenoid?... carb.'s been stripped and cleaned and fuel cut off solenoid at the bottom of the float chamber ain't clicking so assume seized, so wedged that in the open position and'll put a tap in the fuel line ('s possible that it's also used as a kill as it blocks the main jet in the closed position - Angus'll know for sure), but not looked for info. on these yet .....
View attachment 60970 View attachment 60973
couldn't get it to turn over as the electromagnetic clutch driving the deck is seized solid so needed to get it up in the air a bit... so woke the 'Drema from her slumbers and popped it on the bench
removed all the extraneous crud that was never gonna get used again, so' I could get at the clutch better and removed what I could of it ... the main body was a different story .. left this dogged as hard as I could get it overnight with plenty of WD soaking
still solid this morning, so it had to have it
the thin disc, that is
View attachment 60966 View attachment 60965
crank now goes round sweet as and we have compression
finished removing all the un-necessary cr*p that this was not gonna need in its new life as a garden tug and sat it back down on the deck ... as it started to rain a bit heavier
will see about making it run next, with some new basic wiring, minus all its kill switches/knockouts/lockouts/etc. .. fully stripped down for racing
Vicki arrived late afternoon for me to take a look at her wheel .... lucky girl, rim looks fine - two new tyres ordered for tomorrow ... bang a pair on the front and keep the good one to go on the rim I bought Sunday, for her to chuck in the boot if she's going anywhere distant ... off to Manchester next week on a McGuire course she teaches at .... so keep yer phone on standby Paul
@Mogman
fair play to Ruben
@doobin he said he'd have been and sorted her Sunday, but he was away sadly. Fortunately that full size
'supposed' space saver came home sweet as ... never seen the road before, looking at it this afters
did knock these out over the weekend - Pam wants a towel rail ... usually hang 'em on the cooker oven door handles but ain't keen on doing that to her 'new' Stove ...
View attachment 60983 View attachment 60982
just got to assemble em .. CBA to get the Caddy out for four little welds - will have to wait 'til I have a few other things that need the hot stick - like a tow bar for the new tug and anything else I can think of
oh and this got a bit closer to the bench this afters too
... While I had the 'Drema running
still in need of a sheave though
.. no one got one hanging about??
.. have to ask Russ - see if he has anything sat about?
.. everything else'll need designing around it
the wonky looking bolt in front of the Tico is out of the 'Drema's fuel filter mount bracket .. head snapped off again - third one I've had to replace ... bracket has a nasty wobble, ticking over, even though it's made of 8mm plate and bolted solidly to the side of the engine block
.. spotted it when I lifted the bonnet to turn the isolator on
weather is 'sposed to be a lot better tomorrow
.... for a week
