new raised flower beds for 'er indoors tonight thenNew boots day!!View attachment 7996View attachment 7997
new raised flower beds for 'er indoors tonight then![]()
So you finally got yer new bootsNew boots day!!View attachment 7996View attachment 7997
Managed to keep going on the old set until the weekend when working on pulling up an old floor slab and foundations. The old boots literally started to give me all the lugs back!! Think I had made the most of them!!So you finally got yer new boots
You was all over it when I did mine and posted it
Hope you got them from Cautrac![]()
That's an unusual arrangement for the substructure Shaun. Do the brickies only raise the internal skin first and then build the outer at a later point?Been busy doing the clear up, reduce dig, foundations and concrete in the village for a nice detached house. Still keep forgetting to take photos. Just got this one after dropping blocks out on a Sunday!!View attachment 8241
Despite rumours to the contrary I have heard of trench blocks. In this instance we have a 140mm inner skim 60mm cavity and 215mm outer skin. Could almost have gone with 215mm across the width. As it is a timber frame with quite a tight tolerance it is easier to do the inner skin absolutely spot on and let the Brickie’s deal with the outer skin while I am off site. I know that the frame should fit on then!!That's an unusual arrangement for the substructure Shaun. Do the brickies only raise the internal skin first and then build the outer at a later point?
Usual arrangement today is trench fill blocks to match the cavity width.
I was trying to inject some humour!! Should have used one of these.
Done plenty of timber frame work including many of these 3 storey timber frame travel lodges that are going up in flames!! Spend the time to get the concrete right, helps to get the block work right, then the beams sit about right, ready for the next block that has to be right!! Even got some new tape measures as I have managed to break the last of my steel tapes and hate the horrible vinyl fibreglass jobs!!
what's the Ovlov ShaunSomething different. Staying with some friends....View attachment 8274
I did wonder how long it would take to ask!!what's the Ovlov Shaun.... looks like it might be a duck
he'll want one if he doesThe man goes on holiday and takes his work with him.
I wonder how long before you get fed up by the pool and are over there asking the lads for a trial in the duck?![]()
Never driven a duck yet!! They are working on some new housing and there is a JCB backhoe and a bobcat being used. They don’t seem to be very busy apart from starting the diggers at 7am and putting them back at 4pm. Couple of tippers parked up as well. Must have most of there operators on holiday!!! Might see if I can get a shift tomorrow!!he'll want one if he does.... had some decent time in one o' they at the Ovlov dig day in Solihul a while ago ... was no tilty on it, so no-one wanted to play with it .... 'cept me
... was very nice - loved it TBH ... light on the reach, but smooth as silk, so well tolerable
that'll be an education thenNever driven a duck yet!! They are working on some new housing and there is a JCB backhoe and a bobcat being used. They don’t seem to be very busy apart from starting the diggers at 7am and putting them back at 4pm. Couple of tippers parked up as well. Must have most of there operators on holiday!!! Might see if I can get a shift tomorrow!!![]()
Thank you for the advice. Don’t have a switch for axle locks on the Kubota!!that'll be an education then... don't forget yer axle locks
... they'm weird on that
... you can ask Sean Patrick Vincent 'bout the locks on they Ovlovs
IIRC Daz (@Exmayor )was stood there too
... but no one was fast enough on the camera
neither did the OvlovThank you for the advice. Don’t have a switch for axle locks on the Kubota!!![]()
