Can always turn the hitch round on the small machine within a few minsunlikely, on back'ards like that![]()
true ,Can always turn the hitch round on the small machine within a few mins
Video too big to put directly on here so had to upload elsewhere, but this was it at 50 hours. Fitter was out around 70ish and seemed fine but less than 20 hours it's back to the same. All the rams have a lot of sideways movement in them too
shouldn't be any oil at all there .. the 'gasket' will be purely for seating ... if you've oil leaking there you either have a crank seal leaking or your pump seals are leaking - most likely pump ... the 'bell housing' should be dry... had hydraulic oil leak from gasket between pump and engine which I think may have come back.....
I do have a small amount of forwards and backwards play to, but could just be where it lifts.tha's lift though Brendan .... could be shimmed out .... it's not wear in the pins/bushes
shouldn't be any oil at all there .. the 'gasket' will be purely for seating ... if you've oil leaking there you either have a crank seal leaking or your pump seals are leaking - most likely pump ... the 'bell housing' should be dry![]()
8ft, but I wouldn’t let anyone else do it. Gonna treat myself to a pair of 10ft alloy ramps.What size ramps are you using to get it on the tipper? All the talk of ivecos on here has got me thinking about one to use allong side the shogun.
He refitted the gasket and added sealant to it [/QUOTE]
the fact still remains there should be zero oil in the bell housing @Brendan.... he's just sticking an elastoplast over the issue
... ask him where the oil is coming from
...... one of two places - rear crank seal or front pump seal - and both are a fault
Wide tracks.. Do a lot of soft ground work?Just having a stretch in the sunView attachment 7005
digging a well are we Rory?Schemes are Afoot down here....![]()
digging a well are we Rory?![]()
this pipe was steel so not an oppositionHad one like that but with water service. Had to cut and joint
haven't seen that plastic coated steel gas pipe in years ..... perfect 1" bore ... used to make great hinge eyesthis pipe was steel so not an opposition
that's a hell of stump in that bucketwell an interesting weekend got a small job remove some stumps and dig out for a shed simple enough had the multione out again lifting and carrying
thats the simple bit spot the problem in the next one
but dont worry no services in this bit
and she handled it without any complaints the more i do with this pocket rocket the more i am impressed.that's a hell of stump in that bucket![]()
[/URL]
