some where there has to be a PRV in that drive circuit from the Variable pump ... needs finding and investigating ...So what do you suggest I do next please
mini digger thread on here recently with issues .. turned out to be a PRV stuck open with rubber debris
certainly the easiest thing to investigate first .....
presumably the flow from the directional lever's valve block goes to some form of distribution / flow splitter block/valve, to spread it out to all four wheels ...
could see if there's a PRV in the feed to that??
Delving into a VD pump is a last resort
