Ice cream at Hillhead next year.I'm sticking with my guess.
What's the prize?
What's the prize?
No step welding, sat facing south so got natural pre-heat. I went straight through end-to-end both sides.I'm wondering if step welding has been used and there are some tie ins too tidy to see so I'm going 30.
but that's the root Bri
No, you can just see the root to the right.She’s burnt right in to the bottom.but that's the root Bri
Or a bag full of slag!The rod stubs….
not a lot of value in that though Mick, unless you have a slag mill and are using a sub. arc systemOr a bag full of slag!
There’s not much left to weigh in when I’m finished, Gra. Usually the coating has all gone. When I learned to weld I was working for a tight-bottom. I had to stick my leftover bits of brazing wire together to get more out of them.it'll all weigh in![]()
Still standard practice in some placesThere’s not much left to weigh in when I’m finished, Gra. Usually the coating has all gone. When I learned to weld I was working for a tight-bottom. I had to stick my leftover bits of brazing wire together to get more out of them.
absolutely ... and why not -- all costs hard earnedStill standard practice in some places![]()
Nah I've stuck it to another long before thenYep I remember those days too, I think I could get down to about 3” bits before dropping them!
“only started squeeling last week mate”320 top roller. Turned it over to even out the wear.View attachment 50009
Its mate was square.
Hi Bri is that a self made kit? Could do with one! Pneumatic or hydraulic?Track pin removal, Cat 320.
Ok...prob a daft question . I'd have thought you guys would have an OEM puller ? Or do they not exist?Hi Bri is that a self made kit? Could do with one! Pneumatic or hydraulic?
Exactly the OEM ones either weigh 2 tonnes, or the are three legged, which can’t be adapted for pushing or pulling pins on booms/dipper/king post!Ok...prob a daft question . I'd have thought you guys would have an OEM puller ? Or do they not exist?
Looks nice shop built one that![]()
All the ‘own’ ones I’ve seen need a hiab/ another digger to hold in place.Ok...prob a daft question . I'd have thought you guys would have an OEM puller ? Or do they not exist?
