yanmar b03 scopy restoration
Y
yanmarb03
presumably the NiCad operates the solenoid? can you not use the main battery to engage it with .... if it's a lower voltage, could always put a HD wire wound resistor in series, to drop the voltage if needed? (y)
Exactly what we did it's very temporary at the moment but it worked and the engine runs which is good as I didn't want to try and wedge a new one in the small space
Y
yanmarb03
Evening all
Sorry for little updates we have now moved and been on a holiday
boom has gone to shot blasting not expecting much to come back to be honest Believe it or not all pins came out split pins just needed some heat and they came out which surprised me.
I'm looking for a new link I'm not sure what they are called see picture also how to measure them etc
Evening all
Rose joint, or a spherical joint, or a spherical rod end. Any good bearing shop should be able to source these. You need to figure out the thread size and pitch, and if it’s the left hand threaded joint or the right? Assuming it’s set up with a left and right hand threaded bar?
It looks right hand threaded to me, the broken one that is.
C
charlie2
Evening all
some stock cars use joints like that for suspension links etc, and on the bigger f1 cars they are fairly big.
Y
yanmarb03
Parts washer is out hydraulic block and lever controls
Those who commented on the replacement linkage I got a price from a yanmar dealer for JUST the end that had snapped they wanted 95+VAT for just the end
assume that's a spare .... as it's outside and doesn't have a washing machine rubbing shoulders with it ..... getting away with that in it's usual environment'd take a brave (or single) man :giggle:
got one here for similar usage ;)(y)
Evening all
Y
yanmarb03
Finally the boom is back from blasting not as bad as I was expecting to be honest
I have found the rose joints aswell I was quoted £100+vat from a yanmar dealer luckily I have a bearing shop locally that can do them for £5.50+ vat each. Absolutely mental mark up there!
hard to believe that H2O can do that to steel, isn't it :oops: :cry: ......
's gonna take some repairing that ...
ven in the areas that aren't through ...
what's it like internally :unsure: :(
Y
yanmarb03
Nothing to really update you on this project boom is still with metal guy he's super busy as most independent businesses are I have cleaned the boom parts ready for paint
Y
yanmarb03
Help needed again
Can you buy these shims ? Most of mine are very rusted this is the only decent one internal pin size is 20mm external external is 37mm and thickness is 1.5mm or shall I just get some new one laser cut ?
