Williams Woodshed Workshop
My mate’s transit custom blew its turbo at approx 100k miles - apparently it’s really common on them.
They are total dogshit - I’d never buy anything made by Ford nowadays, basically disposable crap.
My 2.2 blew turbo at 167000 and sucked it through the engine. Plenty of good fords on the road..
William127
William127
Problem is its a fantastic van. Super comfy, all the toys you need, loads of room, tows 2.7 ton, decent economy and fast enough to rack up plenty of points if you're careless 😆 🤣
Just seems to have a timebomb under the bonnet 😫
William127
William127
Meanwhile, Instagram vs Reality as da yoof would say 😆
(Yes I know 2 of the photos are like watching Dave TV 😆)
always amazes me how discs can get into such a state with little 'track' coverage and the rest like a badger's bum :unsure::unsure: full width pads - you'd think they'd retain full width clamping 🤬
see you're doing all 4 corners - hateful job on a landy:( and in this heat :oops::oops::censored: - like the fan :cool::LOL:
Reminds me I need to look at the amarok. Coming over the pass last night it wasn't happy in the rear. Only done 40k eats pads...and from the sound discs as well.😑
William127
William127
Got an advisory that the rear discs were generally a bit scabby on the mot.
As always I left it a month or so too long 🙄🙄 Weekends was taking the piss a bit really tbh but I'm glad I went.
Just doing the pads on the front today if the discs are OK
Got to go to Cheshire tomorrow for a couple of days so it's now or never. 👍
William127
William127
Front just got pads, didn't really need them to be honest but by the time I'd pulled a wheel off to check it didn't seem worth leaving.
All the calipers moved nicely and evenly, only bit that concerns me is the back left stub axle mounting plate has a couple of warps, never seen that before! Not on an oil seal fortunately, but I'll change it shortly while it's fresh in my mind.
Must be 6 years since I has a hub off a defender, good to see that I remembered it once I got going, I've learned a couple of new tricks and gained some very useful tools since the last time. The big 1/2 inch milwaukee makes light work of the wheel and hub nuts, the big torque wrench helps you do the job right and the snapped of pick makes a fantastic podger pryer poker 👌
:oops::oops::oops: tester uses a guide dog to get about does he :oops::oops::unsure::ROFLMAO::ROFLMAO:
deffo would not get through round here - even if they clocked enough on the rolling road
William127
William127
Some things the same, some things different- couple of steam fairs, usual works etc.
But I've also finally completed on my flat, only taken 7 months ffs🤣 Collected the keys, dived in for a shower and didn't go back for 10 days as I was away in Cornwall, Cheshire and at a steam fair 😅
So I've put up a shelf, hung some pictures and bought myself a new to me ebike 😆 🤣 👍
New place is about 30 miles north of the yard etc so although it's a town I know a bit, there's plenty I don't know. Headed out on a little bike ride this morning, got to the top of a hill, familiar looking pumping station, oh yeah, we did the exhaust on the genny 10+ years ago 😆
(Photos to follow, signals very hit and miss😒)
William127
William127
Some photos
William127
William127
Too bloody hot for this!
Industrial needs a new water pump, half the front end had to come apart though- unlike the 35 there's a cast front end, hydraulic pipes and tanks and all sorts in the way.
Got it out, only to find the pump I'd been given by a mate wasn't the one I needed- was a 50/50 chance and they're not particularly expensive 👍
While it's apart I've flushed the rad out, decreased a ton of gunk out of the front casting and I'll give it a pressure wash from the inside out while there's nothing in the way 👍 It'll make fitting the headlights a lot easier too.
Also tapped the top casting to m12 so I now have a fitted handbrake, rather than a hanging on to by its rods one 😆 The top casting is badly cracked and will need bolts extracting when I get a replacement, but that is not a 5 minute job so can wait till its convenient 😉
William127
William127
Been a busy day today- started off collecting 1.5 ton from a 2 week hire, then took the Giant out to move a load of York stone and some other bits for a regular customer. Not a bad job, probably about 10 ton in total, had to lift about half of it by hand but got it done I a reasonable time. Popped into town to buy a bike carrier for the back of the defender, for 25 quid including a fully working light board it'll do until I put a swing away wheel carrier on.
Did the last couple of bolts on the plough and put it in the field out the way, sorted out a dodgy mirror head on the defender then a mate turned up just as I was cooking some burgers 😆
Between us we spent a couple of hours getting the water pump and radiator back in the Industrial, as well as putting the headlights in and sussing out the route for the wiring.
Finished up about 10pm after a massive but very short storm, which left behind some amazing colour sky but a massive rise in humidity 🥵 Has been quite a pleasant evening before that.
Been a busy day but a good day 👍
William127
William127
Pulled off the broken door card this morning and fitted this FrontRunner drop down shelf I bought at Billing Land Rover show- last year 😆
It's a bit high but it'll do until I get a chequer plate door card. It was an ex display model, half the price of a new one, very well made. Handy little thing 👍
Ace them got one in our def. Used it way more than I thought. Brewing up etc.👌🏻
William127
William127
Found these pictures of when I picked up the industrial 3 years ago.
Didn't realise (obviously 😆) that it was too wide for the plant trailer 😆
Fortunately I'd put some sleeper blocks and a decent trolley jack in as the trailer was on 13 inch 'low profile ' tyres as the time, terrible for punctures.
Getting it off here was a lot easier!
