Welfare cabin hydraulics
OK .. it's reverse to what i assumed ... can't understand why the LED is changing colour, unless it's due to voltage drop at that DIN connection ... try energising the cetop coil and crossing the starter poles to run the motor ... there'll almost certainly be a relay to operate the solenoid on the motor -- too high a draw for a small push button - usually ... (much like an ignition relay on a vehicle operates the starter solenoid) ... will almost certainly be two relays to operate solenoid on motor - one for the up motion and one for the down motion .... cetop solenoid'll only be circa 1A draw so probably paralleled with motor solenoid's relay?
correction ... assuming your "press it down" in the vid means legs down my assumptions are correct, but that said .... your "press it up" is running the pump motor so do you mean "up" is lift cabin up???? bit confused
No down is retract rams cabin sits on floor
Up is cabin goes up rams extend pump runs
my money is on a faulty relay, operating/controlling the pump motor's solenoid, in parallel with the cetop's solenoid activation ;)
by coincidence these came up in my email this morning @Giles .... these however use a double solenoid cetop to reverse the flow
Rob65
Yes it was haha populated it today for next two Jobs which are all drainage, annoyingly it’s 12’2” with square feet so doesn’t fit snuggly on my two 12’ trailers. Need to weld some lifting eyes on it so can lift it with diggers when no forks available
Giles. Does this mean you will be needing some manhole covers. I happen to know where there are some 😀😀😪
Doesn't stop there though 🤔 spring will push it straight to parallel port
I read that as sprung to stopped ports, but was at a loss to decide what would put the shuttle at parallel ports, other than oil pressure Mike:unsure:
But that would be identified by a pilot symbol 🤔
