correction ... assuming your "press it down" in the vid means legs down my assumptions are correct, but that said .... your "press it up" is running the pump motor so do you mean "up" is lift cabin up???? bit confusedOK .. it's reverse to what i assumed ... can't understand why the LED is changing colour, unless it's due to voltage drop at that DIN connection ... try energising the cetop coil and crossing the starter poles to run the motor ... there'll almost certainly be a relay to operate the solenoid on the motor -- too high a draw for a small push button - usually ... (much like an ignition relay on a vehicle operates the starter solenoid) ... will almost certainly be two relays to operate solenoid on motor - one for the up motion and one for the down motion .... cetop solenoid'll only be circa 1A draw so probably paralleled with motor solenoid's relay?
