I
IvorT
excellent little unit this
Oh the joys
METAL FIBERS (STRUCTURAL): ADVANTAGES AND USES
These fibers are obtained from drawn steel wires.
They generally have hooks at the ends to improve their anchoring in the concrete.
They are used to improve the mechanical behavior of structural concrete (structural role). Their mechanism of action is similar to that of reinforcements (metal mesh) in ordinary reinforced concrete.
Roles in concrete:
Reduction in cracking:
By their anchoring in the concrete, the metal fibers prevent the propagation of microcracks which may be due to the natural shrinkage of the concrete or to excessive forces exerted on the structure.
Fiber-reinforced concrete: locking of a crack by the fibersLocking of a crack by the fibers.
Increase in ductility:
The presence of metallic fibers with the dosages usually used does not improve the flexural strength of concrete as such. However, after cracks appear, it allows the tensile forces to be resumed in the concrete and thus prevents it from suddenly breaking in a fragile manner. They thus give the concrete a ductile behavior.
Good luck finding the metal type
Only seen them Once and that was a huge factory unit 100m x 60m 220mm floors on stabilised ground. Contractor had their own machine that added them to mixer, don’t think they pump too well either. I’d guess if you can get them it’s only be big city batching plants only.
Yeah its interesting....they have sold a type of fibres over here for years, telling us its a direct replacement for mesh in lighter applications, we've been dubious so as with this job any time there was significant load on it we've gone with what we know works ie mesh, but it might well be worth putting fibers in to help with potential plastic cracking or shrinkage as they are not looking for a fancy finish, as @Steve says they can show.
Im well aware concrete is a bit of a black art and a specialist job if your going for the best finishes etc, while we have floated floors and got decent results in thd past nowadays we only do concrete as part of a bigger project and keep it basic, this garage is getting another finish down the line.
I dont pretend to be an expert by any means.
You can clear fibres off surface once done with quick once over with roofing torch, we work with an old boy engineer he’d laugh at the fibres being mesh replacement some marketing ploy from concrete firms to make £5m extra for 50p poly filament fibres
@Smiffy these boys rocked up 7.30am started cutting, been at it 30 mins no water big dust cloud drifting….
Looks like a bt box or virgin
In the day when we done industrial flooring we used Fibres only when directed by client. Nightmare to power float finish.
Used extensively on external lorry parking areas as it improves impact damage greatly. But would still use mesh as structural steel. Would definitely add Fibres to heavy duty external but would say waste of time on light duty or internal.
They really need to be added in bottle mixer at plant. Anyone adding them to a volumetric is really wasting their money. Have some more cement instead!!
A Ringway subby gang got caught doing exactly the same about a month ago by a member of public and reported to HSE. The fallout is unbelievable and because Ringway have all the training and toolbox talks in place the individuals not only got sacked but she are going to fine them.
And there traffic management is carp aswell no cones, no footway closed signs. If you tried that in Surrey you would have one hell of a fine
Looks like subbies?
Does my nut in...if nothing else pisses me off covering cars in crap. Can't teach stupid and they deserve a kicking .
Thats concrete work ...everyone has a different opinion 🙂
