We used to fit a system called biorock with the tank and filter media in seperate tanks, had a vent from connecting pipe and similar could be a pita to get bang on.
If space allows we get units bolted together now with all connecting pipework already in place, most seem to offer a monoblock system now....what are you installing there ?
A vortex unit the second tank holds a pump which will pump to drainage field
Left hooker
Left hooker
Could that be used on tarmac? Be very handy for stripping turf neatly
Not sure what type of plate is used to make the disks on the proper tarmac cutter
Mines mild steel and I used the old incarnation for turf cutting edges of roads
All the tanks I’ve put in have the pumped outlet in the last chamber.. obviously only any good for short pump runs, I guess you have a decent distance/height?
No it's not a big head just couldn't quite get the invert level over the distance, yes the pump is in the final chamber
Yes should be 2 to make 1 so no need for different levels, especially 2.5m in the ground
Right pain that! I added a pumped outlet onto the last tank I installed after I’d put it in the ground… forgot to order pumped outlet from factory 🤦‍♂️
They can work from the bath as long as they do their f****ng job.
I think I will apply.
20% chance of rain with brief spells of sunshine intermixed with possible sleet and strong wind. Pollen count 5%
Nearly made one with 2 discs on a 300mm bucket for e10. Didnt bother in end. Watched interesting video recently where someone cut turf with disc cutter, seemed to work well. Will try it next time .
Upgraded from the dx10 as rake doesn’t fit it trying to mix sand in and then level it out for turf, rained all morning here
Plenty of clean stone behind, perforated pipe and wrapped in fabric.
Could you angle the wall back a few degrees?
I dont think leant back is what they want, the ground is very stable at the back, its only retaining the clean stone.....might have to see if we can come up with a method spanning across to sleepers, but that would mean a lot of load on the sleepers that took the spanned weight.
Clients come up with something that looks nice and we have to see if we can make it work....like architects, all their problems are theoretical.
Urgh! I’ve just kept completely off mine, kids can just go to the park instead 😂
In that sort of situation I'd put in a bit of a disclaimer- like happy to install but if they start snapping off at ground level a few years down the line don't come moaning to me because the phone will be quietly put down 😂
Yep not a bad idea to cover myself but obviously id rather find a way to make sure it cant happen...we usually come up with something as the job approaches.
@6feetdown Yes its too big really ...i started it years ago for the 8t and its been in the way ever since, cut it down to 2m wide and splattered it back together, I wont use it enough to warrant spending any money on steel that I dont already have, going to have a look at the headstock setup so I get the angle right that was discussed previously, after that maybe a bit of plate to retain material at the front like they often do, then I can stand it up somewhere out of the way to get dusty.
@DaveDCB yes poss too lumpy, shes got some power the little wacker but we'll see.
mines at 30degrees but afew less to about 25deg would be spot on.
I had this one and it was too heavy, it’s now on a 8ton hitachi non kingpost machine and even that knows about it! Must of been built out of Irish lead soaked steel 😂 * must say it was ALOT better built than the Digbits one I’ve got now!
