JerryRtilt
That's worryingwell.....as good as a rake bucket is, especially under a tilty... it's borderline !
I think he means the work life balance vs the new rake bucket is borderline.That's worrying![]()
Think I'll go 75Every time I think about a rake bucket I get stuck at the first hurdle, 50mm or 75mm spacing on a three footer, what do others use?![]()
50 on ours great for a bit of riddling tooThink I'll go 75
Giles knows the score...50mm on my 1.5/3 ton one 75mm on my 5 ton one
It really depends what your doing with it. I have 75mm but tbh if it's dry enough to not clog up I'd prefer 50mm as it's surprising what size rocks still gets through 75mm. But if raking root matter etc 75mm is fineEvery time I think about a rake bucket I get stuck at the first hurdle, 50mm or 75mm spacing on a three footer, what do others use?![]()
Amazes me even with 50 what gets through i might put an extra bar across the middle of ours at some pointIt really depends what your doing with it. I have 75mm but tbh if it's dry enough to not clog up I'd prefer 50mm as it's surprising what size rocks still gets through 75mm. But if raking root matter etc 75mm is fine
I went with 75 for the 3t, when i borrowed one last year was given a tip, when using under a Tilty using it slightly offset has the effect of closing up the spacings, which seamed to work.Every time I think about a rake bucket I get stuck at the first hurdle, 50mm or 75mm spacing on a three footer, what do others use?![]()
I have 50mm on mine. Quite often a half brick with frogs will slip through. At 75mm whole bricks will fall through.Amazes me even with 50 what gets through i might put an extra bar across the middle of ours at some point
SameI have 50mm on mine. Quite often a half brick with frogs will slip through. At 75mm whole bricks will fall through.
It I was getting one for the bigger machine I would still go 50mm
Looks like big red will be busy for a bit.Little extension dig out today about 100 ton to come out due to height, into 1 ton dumper and onto front but up a narrow lane so actually getting rid of it is yet to be solved. @hiluxman might be coming to save me with is wagon lol. If not try get tractor and trailer in.
Mine is 50mm on the 1.5 ton, best use for it I have found is breaking out an old slab. Pull out the big lumps and leave something resembling type 1 behind.50mm on my 1.5/3 ton one 75mm on my 5 ton one
Hope you have some Hardox in itMine is 50mm on the 1.5 ton, best use for it I have found is breaking out an old slab. Pull out the big lumps and leave something resembling type 1 behind.
With 75mm gaps it would be more like 6F2 which is hard work with a small machine/thin build up.
