Did it get a new paint job after its fettle? 😎
what it could do with is a PRV ..... with the jet closed off the pressure it built up was remarkable .. possibly what broke the 2.5mm spigot ... was the weakest component and completely inaccessible from the outside to incur physical damage :unsure:o_O
Stick a cetop on it .
Or hang on is that what the deutz is for? A power pack for her tooth blaster 😎
Jimbo69
Jimbo69
Digging out for an extension today, got it all reduced to formation, back tomorrow to dig the foundations.
The engineer likes his steel, another beam to go in where the joists have been cut, then another one behind where I was standing. OTT as usual.
Then home to do a bit of wood butchery πŸ™ˆ
William127
William127
Right mixture from the last week-
Aldi petrol pressure washer going well at at least 6 years oldπŸ‘Œ
Frozen bootsπŸ˜…
Dig out for a patio
Acoustic enclosure installed in the back garden of amazing 'grand designs ' type house in East London- old house, built in the middle of 2 rows of terraced houses. Turned out they built the first house, then decided to build the roads north to south, not east-west!! So you go down a 50 yard alley to the front door of a multi million pound house, basically in 30 other people's back gardensπŸ˜…πŸ˜…
Radiator out of a Cummins DongFeng generator for a steam clean, alternator split from the engine for a rear oil seal replacement, great day out with a full crew for a big day's spanneringπŸ‘ŒπŸ‘Œ
Discovery got jealous because I bought the defender new doors, but at least I know I'm leaking coolant, not 'loosing' itπŸ˜‰
Micro and Giant out this morning doing the annual shove up of the leaf/soil pile at a customers. More of a 1.5 tonner job but I needed to get under some trees for a soil raking job there.
Windblown chestnut and felled silver birch dealt with with the 1.5 Case yesterday morning/this afternoon.
Busy few days, similar to come the next couple of weeks πŸ‘πŸ‘πŸ‘
Can you make access to the field for the new tennants tractor but keep the 3 other paths accessible! Trying to work wonders in an old muck heap/midden. Rounded up some big uns to make a bit of a retaining wall
Left hooker
Left hooker
I’ve done bursts on terraced rows before, not fun. I’d just go and knock on the doors and say β€œthere’s a leak on supply pipe, water will be off for a short period at 11am”. Have a couple of these ready along with your new section of pipe ready made up and should be fairly quick changeover, most will probably never know!
Or a couple of these and put a length of blue between that's flexible
It’s amazing what abit of black tape on the dash hides….
Would hide the 2 or three lights, but the stupid system when it detects abs sensor fault, pretty much shuts down...
No front or rear parking sensors
Radar turns off, so no pre collision assist or cruise control by distance to vehicles
Hill descent control
Hill start assist
Traction control seemed to be off
Abs reduced or off, both of which was a bit s**t on an iced road, rear tyre lighting up and not able to stop, although was iced up a bit so may not have been any different?
So possibly stability control and Also the trailer sway assist
There is probably some other bits too 🀣
Managed to get it out with it snapping three times, with a trip to Halfords then Screwfix to try and get some different easy outs, as mine were too big when it got down towards the end of the sensor.
All in all nearly 3 hours for what should have been a 10 minute job
Hill start assist
Sorted then!!
Hill start assist
the old shape navaras wont go into 4wd with the abs light on. Which is very amusing when your mate goes ploughing into a great big muddy hole in a heavily modified off-road truck. Breaks an abs cable and is now a 2wd and very stuck
Bits and bobs today, tryjng to get done and away.
Finished access to field got some gates and hard standing down, repairs to lane from water.
New auger mounting
Deer around where we are working
that was quick ..... took me at least that a side on the P38 fronts when i did the swivels ... and they were on the bench :oops: .... can't drill 'em out cos there's this bloody hard as glass magnet in the bottom of 'em ... extracted a fragment at a time :(:mad:
replaced with half a bucket of sili grease a side :rolleyes:
you have my sympathies
Had the morning under the low loader trailer doing a pre MOT check 🀞
then in the afternoon pulled the seat and box it sat on out
so I could fit this
then seat box back in
just got to fit the control box to the armrest tomorrow after the MOT😳
Routy56
Routy56
