are you able to get a drift on top of the bolt heads to give them some shocks from a few hammer blows ... then perhaps an impact wrench, even if it's just a manual type of impact driver to 'break' the initial stiction in the threads ..Not good I am afraid, I can’t seem to budge the bolts that hold on the slew motor (part 8.010) above. Is there a away of rotating cab without remove of this.
blows to the heads via a drift will help dramatically
heat to the heads is also a winner, it's whether you can actually get heat to them without doing any 'collateral' damage to the surroundings.
one method of doing this is a 4 / 5 mm electrode shorted to the head of the bolt .... that'll warm up the bolt and 'upset' any corrosion causing stiction ... the rods'll warm up pretty quick too, though
looks a right bar steward to get at, in the drawing
