All's well that ends well I suppose but nothing worse than not getting to the bottom of it.
No doubt the problem will reappear again at a crucial moment when you desperately need itAll's well that ends well I suppose but nothing worse than not getting to the bottom of it.
Well if all you need to do is give it a good hard stare (like Paddington bearI went upto her this afternoon, had a quick look at the dead man lever switch, seems to be in good enough condition, clicked it a few times and sound nice and positive in the action. Thought to myself it's something else causing the issue. Had a look about some of the wiring looking for a bad earth or something. Must have spent 15mins looking and thinking about it. Sat in the seat again and turned the key and instantly fired up.
. I didn't do anything other than look at it but what ever it is it seems to be fine now. I tried with arm up and down, on and off the seat but starts no matter what!
Now't like a "Padders hard stare" to put the beejeeezus up summatWell if all you need to do is give it a good hard stare (like Paddington bear) I’ll have your numbers then any problems I get you can have a LOOK
Now't like a "Padders hard stare" to put the beejeeezus up summat![]()
That's the worst thing about it.No doubt the problem will reappear again at a crucial moment when you desperately need it![]()
won't bloody work after that thoughJust have to put all the panels back on that I striped off yesterday looking for the fault.
aye too right thereif only it worked when you want it to
This statement is freakishly accuratewon't bloody work after that though![]()
Amen, let that be the end of itResult
