......then in the late afternoon, my neighbour James said, "Dave before you go on holiday can you just dig out a bit for concrete for my new garage"
"Don't worry, it dead, I've disconnected it from the consumer unit"
So pulled in a skinny trench for services...
Then worked up towards the other new build shed...
He initially told me he wanted a 600mm by 30m deep trench
So I asked him about the secret bunker that he was building
Jack took the spill away to our heaps. So what he doing is adding 600mm slab to the existing old garage slab for the new build. He will over engineer it with reed bar etc.
Can you see that the light was fading with the eclipse. We looked at it with my welding mask
James was really happy with our help to get the prep done. Job jobbed
As a footnote, James is a heating engineer who specialises in renewables.
We have been helping him out because he will be helping me out with an install of air to air heat pump stuff.
First he will be installing his own split units and I will be helping.
Then I will install my own split units. Will probably go for 2 big outside units with 3 indoor units on each
