R.Sanders Plant
I'd honestly have another 05 plate in a heartbeat. The mileage that lorry did and the loads it carried would of killed anything else i'm sure.
Trouble is most that are still around are 5 tonners.. not ideal sadly.
Spied a couple Canters which are nice short wheel bases :)
I’ve still got an 05 Iveco tipper with the 3l engine - it’s an awesome tow vehicle, bags of torque. Mechanically very strong vehicles.
Good pictures there, Rory, especially the Dear John. Is it a bit nose heavy with a bare arse? The old 100b’s needed a good counterweight to sit flat without the backhoe on.
Yes it is... But running bare for a reason, can lift the arse end in sticky ground and self recover a lot easier :) also keeps the weight right for on the lorry! A project this year is to sort the scarifier out for the back :love:
Breakdowns, and projects
Got given it believe it or not 🤔 galvanized tipper.... Shame the cab is rotten underneath as it's a good truck tbh
I had similar, was a proper flintstones truck but by heck had it done sime graft. 465kms
Worked out today that I own the first 175 I hired 😂 Number 38270.... glad I did'nt take the stickers off now!
tha's a hell of a coincidence Rory :oops:(y):giggle:
Bit of a result so far... Haven't had to use the winch as after clearing the brash the site is less steep than advertised.... so we are zigaty zagging downhill :love:
Forgot to ask how did you plumb the winch in🤔 of the blade with a diverter valve🤔
T'd Off the blade with Q/R Couplings. Was going to fit a valve but tight on space. Blade down for Spool out, Blade up for Spool in :unsure: Works well enough, might fit a valve at a later date BUT the flows aren't great running on the littleun. So the winch will probably get bolted up on the 7 tonner (it's on a 3 bolt frame so easy enough!) for the majority of work as it's far too slow for timber extraction.
Have you got the umbrella though? .....you’ll f****ng need it!
I'd of needed a f****ng Engcon Tent and Liferaft to keep the Tilttard Tears away from me if I'd brought this mornings discussion for £400 and stuck it on the Kommie!....
what you been ogling now Rory
