That extra 2ft makes it nigh on impossible to swing into narrow gateways on a single track lane in my experience....14ft is just doable16ft nice as well![]()
It’s an utter dream to move a digger with compared to a flatbed however.There's something very satisfying about using a trailer for all sorts of different tasks. Plant trailer is nice but one trick pony more or less
Agreed . 1054 longest part of loading a machine is strapping it on . Awesome trailer ..in case case it hasn't been said beforeIt’s an utter dream to move a digger with compared to a flatbed however.
And I spend a LOT of time moving diggers!
Your absolutely right but today I was using the flat bed to move digger, then dumper then the roller! and takes about 4 mins to deploy prop stands which I guess in the grand scheme of things isn't the end of the world! If I only was allowed one trailer I suppose it would be a flatbed though for versatility.It’s an utter dream to move a digger with compared to a flatbed however.
Talking of one trick pony’s, I always fancy one of these .There's something very satisfying about using a trailer for all sorts of different tasks. Plant trailer is nice but one trick pony more or less
PayloadTalking of one trick pony’s, I always fancy one of these .
Probably favourably comparable to a 3.5t IW tipper?Payload....ah never mind
No real benefit of it over just a standard tipper is there!?Probably favourably comparable to a 3.5t IW tipper?
Hence the one trick pony comment!No real benefit of it over just a standard tipper is there!?
Yeah my Brian james has been doing similar.There's something very satisfying about using a trailer for all sorts of different tasks. Plant trailer is nice but one trick pony more or less
820kgProbably favourably comparable to a 3.5t IW tipper?
yeh I've had all sorts of tish in my 8x4 IW plant trailer that I bought off Ollie, with lil Jakie inYeah my Brian james has been doing similar.
Today's load
Seeing a lot of half pipe tippers 8 legged and artic round here nowNo real benefit of it over just a standard tipper is there!?
Your little 2t dumper for going down a footpath?Your absolutely right but today I was using the flat bed to move digger, then dumper then the roller! and takes about 4 mins to deploy prop stands which I guess in the grand scheme of things isn't the end of the world! If I only was allowed one trailer I suppose it would be a flatbed though for versatility.
Sold that way back. 3 ton terex which at 190cm wide is flatbed only job. Miss the little 2t a lot though for this reasonYour little 2t dumper for going down a footpath?
Sounds like all of those would have fit in a GH1054![]()
Ah I see. Yea a three tonne is right pain to shift.Sold that way back. 3 ton terex which at 190cm wide is flatbed only job. Miss the little 2t a lot though for this reason
