OOPS
Richard Hunton
Richard Hunton
Snap,
This was up ere last year, caused holly hell was 8am, they took a 3cx to it, tore it off the wagon and opened her up.
Apparently there only 2or 3mm steel🤔
usually 3mm .. 2 mil 'd wear out too quick
What am I missing?
concrete = no good to anyone after that
drum = no good to anyone after that
so why do that?
What am I missing?
so why do that?
'cos the likes of EMR are not gonna take a drum full of compo ... an' it's a hell of a lump when set ......... plus a lot easier to deal with the chassis cab once emptied
mart1602
brother in law wotked for readymix ,spent a couple of days with a breaker inside the drum cutting out conc when the bearing failed
I get that, but if your destroying it, then take the drum full away and knock it apart with a pecker imo, wouldn’t take long with a big 360, do it immediately and the concrete won’t put up much of a fight. Can’t see why you’d go to those lengths on the side of the road, not to mention the mess.
When dealing with the highways you have to do whatever is deemed quickest to open the carriage way especially if a main route
It would take a fair size crane to be brought in to lift that barrel loaded on to a low loader whereas the council have grab lorry's on 24hr a day call out so it's relatively simple to tidy up
They do have some bizarre ideas though
pulling the mixer back over full would take some doing, unless you had a large crane on site .... empty it's much less of a challenge ... see there's a set of lift chains around the drum in the vid ... obviously failed to upright it and are emptying it to upright it'd be my best guess
Ok so if it wasn't too high wouldn't be a problem obvs but why load that way round. Probably couldn't wrap arm up enough for step in trailer or truck cab.
