I've only ever had an issue with traction whilst towing once, the car in front slowed down for some random reason on an uphill corner, I had to hook first gear and she spun up. And it is a bit scary especially with traffic right behind you! Grabbed the 4wd switch and sent it! She made it fine but was a bit hard to get back out of 4wd when I found a layby to pull over in.
With decent tyres and some pace its never a problem.
Where I really miss the landrover is in its stability, engine breaking downhill and the ability to use low range to shunt around, especially reversing around a corner uphill - the nemesis of a pickup with the tow bar a fair way behind the axel!
But in every other regard, the Navara is a great daily vehicle. I've done the hot pipe twice (it still leaks a little) and cleaned the EGR pipe out as it got blocked. Also had a NOX sensor go. But all in all, that's fair I think for a 7yo truck that works for a living.
Its got to last another few years yet until someone works out a way around these BIK rules. Mine's good under the old rules until 2029 - it will be well due a replacement by then!
And I still have the old Landrover.... apart from appreciating sitting on the drive, its always ready to start and do a job if the modern car has a hissy fit I cant solve. And might just be an option to run going forward. At £45k for a new pickup, I could buy an old landrover or discovery and completely overhaul/ upgrade it for that. And apart from turning down any work near London (which would be a bonus to be honest) it would be cheap to run, easy to fix and back to reliable motoring. Its tempting....
The only thing I like about modern cars is cruise control, air conditioning and apple car play. Everything else is worse than an old discovery was back in the day!
