Mogmans creations 🤔
The poxy things you refused to buy new for that creation then go a blow a couple of bags on set of tracks!
I know what your saying but I didn’t want to spend any money on it just in case it was a lemon😩 plus I do like a challenge 😂 and as V8 said a lump of scrap if it doesn’t move, used it for a day on one track😳 to level stone for a concreting job but was hard work🥺
Had a result today found this on the scrap pile
just had to fix the pivot pin catch and stick a plug on👍 oh and swap two wires over in the switch as it was running backwards 😳 as I know my phases are running clock wise😉
Had a result today found this on the scrap pileView attachment 25881
these are the originators of the Kepp stuff in the UK Mog .... the Bushnell Bro.s - Hugh and Julian ... have had a lot of gear off them over the years .. nice guys to deal with - for Mormons - if you want any bits - or belts .. 60 or 80 grit're the boys for removing it ... you need another one now for half worn belts for 'less aggressive' grinding :giggle::giggle: ...... they're awesome tools
under the belt on the flat platen is a graphite impregnated pad .. they do tend to deteriorate :( - cheap enough to replace and easy enough to do
just found a pic of that graphite pad under the belts @Mogman
Only one solution...... Mogit
sadly if he Mogs it he will break it .. :cry:
Old FJ Ewdwards gear like that is only designed to have the effort exerted on it by the way it was made for originally ... and a large pair of arms to make it happen
was one of them on FB market place a few months ago .. Identical machine :rolleyes:
Looks like it's on borrowed time then 😆
What could go wrong adding a little hydraulic to it 😲
You doubt it's mogability
they're fragile things, abused Rory ... they had a designed inertia/energy input .. exceed it and things tend to go south with a bang
we’ll see 😂😂
Well I sold it in the end would of been sad to it explode😳
anyway going to have to make a better hydraulic cooling pack for the little Komatsu🤔 fuel tank melted that was near the spool block
managed to patch it up with a heat gun and a bit of 5 gallon drum
Used some cable ties as ”welding rods” 😂
doesn’t look pretty but it’s keeping the fuel in😉
could you not bond some thermal protection on it @Mogman azzy/glass matting with a foil face to keep them separated ?
