MacAulay Plant Services
Is that due to cold weather and waxing or just poor quality fuel with crap in it? Also red or white diesel?
Out of interest is everyone behaving and using white diesel where they should? 🤔
No choice up here Dave , a guy I know ran his tank dry and then switched to white . The big machines were not showing any evidence of red in no time as high through put but his small plant got used less so . He had his roller on site . It was running on white but still had red in it as he hadn’t run it out in red before topping up with white . His plant was dipped and he was fined 1700 quid for the roller
how long past the April cut off was that Vin? ..... there was supposed to be latitude / leeway for that sort of thing .... Think I'd have fought that one, with an infrequently used m/c like that ... there was no requirement for machine tanks to be purged -- only bulk tanks / bowsers ... first offence was also supposed to be £500 fine ... the 30% value of m/c (which i'm guessing that represented) was second offence with confiscation on the third occasion :rolleyes:o_O
Canal Navvy
Canal Navvy
If it happened exactly as reported that sounds like a real abuse of power 😡
It's the sort of thing that makes the ones that try to apply rules look like fools and leads to even less respect for "the authorities " 😉
Rob65
What’s the score if you filled the fuel tank on every bit of equipment you own just before the deadline in order to empty your stock of red from your cans but then haven’t used some of the machines since?
I know someone who has a diesel wacker and diesel mixer, neither of which have run for over 12 months.
From my understanding the deadline was announced in plenty time so that by the time it came round you would be changed over to white not so you could fill up on red the day before.
It was very recent . I don’t know all the details but apparently the outfit that did the checking up here are self funded so they are being pretty officious.
I heard it third hand so will check on the details and post it up here .
There was definitely some guidance from HMRC regarding change over. It was said to be acceptable to fill the night before and use that tankful. I took pics of the machine clock on the 31st March. Been using white since, however, my roller has done probably an hour since the 31st March!
they're all self funded by the fines, etc., but there was a protocol laid down ..... dare say it's in the fuel thread somewhere and should deffo still be on the gov web site ... first incidence was deffo 500 quid fine
dare say there is a lot of kit about like that too .... and before anyone says it --- certainly is here .... not done a lot with any of me gear, last 9 months for various reasons :rolleyes:
but there was nothing stopping you from doing so before April fools day and running the machines out after ... just weren't supposed to refill with red after .:rolleyes:
bobthebuilder
self funded ,i smell a fiddle ,will they be legally allowed to enter a premisis without permission ?
Customs and Excise have more power of entry than plod ... and yes and what's worse, take possession of/seize/disbar you from, said premises with sufficient cause
Thomas7740
Thomas7740
Brothers boss had a digger dipped at half six one night working at a private house. On white so all was fine.
I know a fella and his brother in law got dipped on the 1st day it was brought it, £1500 fine for red fuel in a mini digger.
My diesel man lives in the same lane as us, he reckons they will trace a lot illegal red diesel use through paperwork. He has to keep track of who he sells red diesel too each month and submit it to customs (pretty sure he said customs but can’t remember).
yep RDCO scheme ....
been operational for over a decade, maybe 15 years or more ...
I used to have to do it every month -- Registered Dealer in Controlled Oils ...
based in Neecestle C&E offices
used to be 100 ltrs or more - full record of customer ... may well have reduced the quantity for compliance - I de-registered in 2012
I'll ask my oil guy if they've dropped the max 100ltr sale before full records needed?
RDCO return below in PDF, from my time, ;)
All this 1500 quid fine sh1t, is not what was advertised on the website in the run up to April 1st :mad: :mad: :mad:
  • RDCO HO5 RETURN FORM.pdf
Thomas7740
Thomas7740
Yea he said he’s been recording it as long time but never bothered submitting it, but they were at him to make sure he submits it monthly now
