Fishy
Undo the big red plastic cap - probably needs a 32mm spanner on the square ‘nut’. There should be a filter under it held down by a spring. If you can see straight into the tank the filter has been binned.
The filler cap does have a rubber seal and no oil LeaksSort out the filter and cap first, you may find that once that is done, it will change things.
Hi mick I know what you're saying but I keep going back to I was slowly moving backwards there was some sort of click and the engine stopped dead and the machine hasn't moved since yes I have changed the bottom hose since then but what can stop the engine like thatExample I recently cleaned the water contamination from a 2t thwaites hydrostatic dumper, there wasn’t a filter available for a few days, so left out the t steering and tipping worked fine, but it wouldn’t prime the hydrostatic pump so wouldn’t drive! Filter fitted, drove normally.
sudden hydraulic loading would stop the motor, particularly on tick over, but doubt it would sound like a "click"? pump drive is obviously still functional as all else is working from separate pumps on the end of the main.Hi mick I know what you're saying but I keep going back to I was slowly moving backwards there was some sort of click and the engine stopped dead and the machine hasn't moved since yes I have changed the bottom hose since then but what can stop the engine like that
@Mick-the-fitter is the drive pump a VD? if so it could be in neutral and not upstroking on demand .. control spring collapsed?
would guess someone lost/didn't have the right length bolts and packed them ..... piston pump for sure .. where are the feed and Pressure lines coming in/out can't see them from those pix ... assume the very top line on the 'block banjo' is case drain.View attachment 37626I was hoping you could tell me is it repairable if you look at the photos I just put up what's behind the plate below the leaver it been spaced out with 3 nuts on each Alan bolt
How can I check I have a endoscope to have a look inside but don't know where to look and what to look for can you advise pleasewould guess someone lost/didn't have the right length bolts and packed them ..... piston pump for sure .. where are the feed and Pressure lines coming in/out can't see them from those pix ... assume the very top line on the 'block banjo' is case drain.
I'd guess the button under the lever is pump control @Mick-the-fitter ?? .... being optimistic, I'm hoping it's in neutral and not pressurising
@Mick-the-fitter is the man for this .. he'll almost certainly have 'been in there' beforeHow can I check I have a endoscope to have a look inside but don't know where to look and what to look for can you advise please
yes.. tip, etc. is working fine ?Does it start?
Does it start?
assume so as tip etc. appears ok.... got no drive everything works except the drive . As I said its an old machine so it hasn't got solenoid on it I'm afraid that something broke when I was reversing ......
don't 'spose it's on a roll pin Mick? 'praps accessed under that plate with the long SHCS with the packer nuts ...Sounds like the splined shaft that drives the swash plate for the hydrostatic pump has stopped driving the plate for some reason!
The plate with the packer nuts, looks like its over the forward/reverse valve, looks like the fwd/rev lever coming off the top of itdon't 'spose it's on a roll pin Mick? 'praps accessed under that plate with the long SHCS with the packer nuts ...
's obviously been off before
first thing it wants is a bloody good wash off, drain the tank down and either whip that plate off ... or pull the pumps onto the bench, for a better view![]()
Yes it very easy start don't smoke all the hydraulic work but don't drive we have jacked all 4 wheels up nothing at allDoes it start?
