JBASport
That is so helpful. Thanks again for all your input. Really appreciated. Take care, Terry
no prob.s ... 's what this place is forThat is so helpful. Thanks again for all your input. Really appreciated. Take care, Terry
I would hazard a guess that they are JIC fittings, a 3/4 JIC has 16tpi unf.I have attached a picture of the 2 plugs. The black one is the original and shows the wider shoulder for seating the 'O' ring. In the manual it refers to the ports in the valve block as being 3/4" - 16 if that helps? Terry
Dowty’s don’t always work where there should be an O ring, due to the tapered seat just before the thread.I would hazard a guess that they are JIC fittings, a 3/4 JIC has 16tpi unf.
If you use a bonded seal/dowty washer, rather than just an O ring, you should be OK with what you have.
Any thoughts on where to source proper 3/4" UNF blanking plugs for above in the UK? I live in Scotland and all the ones I have see online seem really expensive and I only need about 4. Thanks, Terry
buy on line ... waaaay cheaper than ordering over the phoneMany thanks
Cheers
Terry
