Can’t see any cash machines - what’s the point?A big blue one blocking the road this morning View attachment 69247
How boring is that though!Re the Terex - @£15K - JCB backhoe loader welds had a design life of 12,000 hours, (& the F N R shuttle typically failed at about 7,000 hrs)
Not sure if relevant to Terex (MF) This has done 10,500 hrs. Think I would listen to Doob & put the 15K into a modern mini
You just havent found the right (down) hill.! Wackers EW100 supposedly is 40kmh now. But i suspect that is very much restricted to gentle declines and possibly on the flat. Id say mine is about 18mph on the flat perhaps as much as 5 or 6 mph up an inclineSadly never found a small duck capable of 25 mph. Oddly at the place where my Gopher is now stored there are 3 Yanmar tracked inc a VIO 26 with a fabricated add on to blade set of forks! I gather this OK as long as the brick truck driver does not stack the pallets one on top of each other. It also has a tilty QH & a mech thumb & an auger lying by it. Sadly I did not have a camera with me. Looks well equipped. Others were a VIO 10 & VIO micro - both tidy but with front stick direct levers rather than side servo / cable set up. Will get pics next time I am there
My Doosan 10 tonner will sit at 40kph on the flat, had it up to near 50 downhill a couple of times when I’ve not been paying attentionYou just havent found the right (down) hill.! Wackers EW100 supposedly is 40kmh now. But i suspect that is very much restricted to gentle declines and possibly on the flat. Id say mine is about 18mph on the flat perhaps as much as 5 or 6 mph up an incline![]()
Jus' playin' ....Yeah I used to hang a set of euro 8 forks over the blade of my 3 tonner worked well. Especially for fencing as would load the forks with stakes and have post rammer on so could toddle everyone along together.
Bet that's a couple of bob
But no different then a duck ref steering wheel? Although all the dash and bulk of the steering column might be a painDid anyone else check the date? I mean, its an interesting concept, but wont you have a steering wheel in the way when digging? One advantage of a backhoe is a good view high up looking down into the trench. Its a very complicated way to achieve dual steering but it would make driving in reverse super easy with the wheel rather than a toggle as JCB do it.
Wonder if you can have it at 90 degrees as well, worst/best of both worlds!But no different then a duck ref steering wheel? Although all the dash and bulk of the steering column might be a pain
dash could well be side mounted and my steering column's no more than about 65mm in dia.But no different then a duck ref steering wheel? Although all the dash and bulk of the steering column might be a pain
I did wonder the same - whether it's degree of rotation is variable ? @APhillips ???Wonder if you can have it at 90 degrees as well, worst/best of both worlds!
