O
Old Operator
Lovely pics of the agricultural BTD6 . Had a look at my old B100 handbook which shows track frame pivots on sprocket shafts needing weekly greasing - along with an engine front support likewise with a grease point - can only presume this is an equaliser bar. Seem to have memories of having to remove track frames to change sprockets but was so many years ago might be wrong. Seem to remember that if the frames did not pivot off the sprocket shafts this was called a 'floating final drive' as boasted by some makers.
I'm pretty sure the IH 'Hydrospring' was a fudging device to allow arm rams to contract if the bucket hit a solid boulder in the ground, allowing the tracks to lift & lose traction thus protecting the transmission case etc from stress as the loader frame was an add on. The 933g being all solid between track frame & loader frame did not need a hydrospring. Bristol / Track Marshall small loaders had a sort of accumulator for the same purpose.
