GB Groundworks
Randla
Randla
Interloper
Of course not, Dave. They'd struggle to get their horse to pull it that far, for a start šŸŽ
Our trusty old sumitomo is missing the bottom front window, i have the frame, I was going to get a piece of 4mm plexi glass for it?
too thin? Will fade really quick? Etc
or get the plant glazer out and do it properly?
6mm Polycarbonate ... or the real McCoy ... depends who/what's the easiest for you ....... the poly'll last years (y)
Poly is cheap and easy and will last years, although obviously scratches easy. A lot depends on the geometry of the pedals. Do your boots touch the glass when tracking? If so it will scratch first time out.
T whiting
T whiting
Poly will yellow and scratch I'd go glass as it won't be expensive to get a piece of laminated cut.
It would be even cheaper if you take the frame to a glass supplier
Im missing the rubber seal was the only thinking with the plastic
or just make a hardboard template
Rob65
I used polycarbonate sheet in the bottom of the door on my old 801.
Glued it in with black butyl rubber which cam in a cartridge from Wickes.
put a layer of goo on the metal and pushed the plastic to bed it down. Then put some masking tape on the outside of the plastic about 1/2ā€ from the edge, applied more black goo and smother it off. Once tape is off from 10ft away you don’t even notice it’s not the proper rubber.
This week has been a change to last -5 last +12 this t shirt weather, laid some slabs Monday then wallers been in doing the stone wall so we’ve been cropping and supplying them with stone. Broke a weld on cropper using it to split 18ā€ by 40ā€ logs haha šŸ˜‚ kind of splurted some hot metal into it
new trailer had first proper outing and Takeuchi is eat a fan belt riddling some stone, wet one today here.
Oh got a thing for bahco adjustables have them all from 4ā€ to 18ā€ just waiting on a 24ā€ a right money. (Some of mine got stolen so replacing them)
New rake bucket, sadly didn’t watched @Gunners video before I ordered it or I’d have got the Hardox dig bits one. Had it set up to go on both 3 ton and 1.6 ton so have a front 35mm pin turned down to 30mm for 98mm of its middle section then a 30mm rear pin at centres for mini. Sadly the couriers lost that pin lol so waiting on another one. Used it few hours yesterday clearing up some builders waste piles to make a lawn area. How I haven’t had one for all this time I don’t know, cracking bit of kit.
@V8Druid what lathe do you think this is? Requested some more pics
