Jimoz
Did you use the struts that the AI spiel reccomended in the end or did you research a pair?
I'll have to go back and look see what it came up with Jim, but what I ordered, I sourced from their online selection system, which didn't have an exact match, but was close enough, dimensionally, other than the body being 30mm too short, hence my extension pieces ... the stroke, body and rod diameter were perfect, as were the mounting studs for the mounts I re-used
I'll take a look at what the AI suggested and get back to you (y)
