been a busy day with a lorra 'can you justs' ... mowed all the grass yet again - still growing well .. our little 'dry weather' spring is back for the first time this year ... only appears after it's been dry for a prolonged period of time.
Pressure washed three cars .. all covered in pollen and looking yellow and after tea ... set about the Haner
Only way I was going to get it sorted was get the ram out ... which eventually ended up with me taking half the grab apart to get the pins out
View attachment 48240 View attachment 48241View attachment 48239
not got a huge stock of 1/4" fittings .. don't do much with 1/4" .. so had to work with what I had (and get more if needed) ... tried a few configurations
View attachment 48238 View attachment 48236
and eventually got ports lining up
View attachment 48237 View attachment 48235
had to use a tee and blank the one branch eventually - short of a fitting - but it was lining up nicely
View attachment 48234 View attachment 48233
the tab holding the cylinder base pin is a nightmare to get out/back in - one position only will it move and clear everything else -once you've removed the shell- it's shaped around the shell pivot boss ..
stood thinking HTF did they get this in there FFS
getting it all back together was 'interesting' ... and a bit tight ..
View attachment 48231 View attachment 48230
'bout the only unions I'm going to get in there are banjos ... will get some shorty tails made up and reckon the two long-ish 1/4" hoses I have should be about right
might take the ram back out and take it with me to Fast fluids and see if Marty has any better suggestions/alternate fittings, or even see how he is at making up some steels, but they'd need to be small.
did discover that one of the pins is missing a locking tab
@Tintan28 - might be worth you checking yours out for missing tabs ... this un's never had one fitted .. better safe than sorry .. one of the shell pivots ... have it drop out and it'll twist the whole thing .... got a tab to make .. fortunately it's an easy one .. there's one in there holding the ram body that's a work of art to extract and will only come out with the shell disconnected and in a certain position .. was bit of a head scratcher
View attachment 48228 View attachment 48229
but ...... after much fiddling, juggling and fannying about it is in there
