It looks like that would be a good idea, but it ends up being too rigid.
As the bits heat and cool (not to mention the pressure), the internal strain will cause fatigue failure.
Looks very close but would the banjo fittings not screw into the ram ports with a lock nut and douwty washer to seal it then put check valve in-between with douwty washers and the hollow bolts ?
That would move the check valve around and more room for the hose ports
even with the banjos in as far as they'll go (without room for lock nuts and dowtys) it's too long by circa 4mm Stu :( Having pondered it last night, what I need now is either some swept 30 or 45 M/F elbows to turn the check downwards some more. Going to take it back out and have it with me when I go back to Raglan for the hose tails ;)
hopefully there'll be sufficient movement in the unions to cope, especially with a couple more swept,s in there ;)
Rob65
been a busy day with a lorra 'can you justs' ... mowed all the grass yet again - still growing well .. our little 'dry weather' spring is back for the first time this year ... only appears after it's been dry for a prolonged period of time.
Pressure washed three cars .. all covered in pollen and looking yellow and after tea ... set about the Haner
Only way I was going to get it sorted was get the ram out ... which eventually ended up with me taking half the grab apart to get the pins out
View attachment 48240 View attachment 48241View attachment 48239
not got a huge stock of 1/4" fittings .. don't do much with 1/4" .. so had to work with what I had (and get more if needed) ... tried a few configurations
View attachment 48238 View attachment 48236
and eventually got ports lining up
View attachment 48237 View attachment 48235
had to use a tee and blank the one branch eventually - short of a fitting - but it was lining up nicely
View attachment 48234 View attachment 48233
the tab holding the cylinder base pin is a nightmare to get out/back in - one position only will it move and clear everything else -once you've removed the shell- it's shaped around the shell pivot boss ..
stood thinking HTF did they get this in there FFS o_O:unsure::cautious:
getting it all back together was 'interesting' ... and a bit tight .. :rolleyes:
View attachment 48231 View attachment 48230
'bout the only unions I'm going to get in there are banjos ... will get some shorty tails made up and reckon the two long-ish 1/4" hoses I have should be about right (y)
might take the ram back out and take it with me to Fast fluids and see if Marty has any better suggestions/alternate fittings, or even see how he is at making up some steels, but they'd need to be small.:oops:
did discover that one of the pins is missing a locking tab :(... @Tintan28 - might be worth you checking yours out for missing tabs ... this un's never had one fitted .. better safe than sorry .. one of the shell pivots ... have it drop out and it'll twist the whole thing .... got a tab to make .. fortunately it's an easy one .. there's one in there holding the ram body that's a work of art to extract and will only come out with the shell disconnected and in a certain position .. was bit of a head scratcher:unsure:
View attachment 48228 View attachment 48229
but ...... after much fiddling, juggling and fannying about it is in there :giggle:
Druid, and if that pin had fallen out and twisted the grab most manufacturers would say “Sorry but you have messed about with it, warranty is void”..
You can see why they sell these things at auction with no guarantee 😀😀😀
made me wonder if that was why it was in there in the first place ... couldn't be arsed to put it back through the factory for retro fit .. crazy I know .... but big outfits do operate that way :rolleyes:
interestingly the outer end holes are an interference fit on the pins, with the starter holes a nice clearance fit ... needs a good tap to shift out of the interference holes, then it's a pull out with fingers
David @Tintan28 ... have a damned good look over yours ... see if there's anything missing on yours too .. better to sort, pre-event, than after, if there is ?
Those little tabs spread as well an cause the pin to rotate... Worth put a weld on them also.
Got love the Chinese 🤫
T
Tintan28
Thanks for the warning @V8Druid but you’re speaking double Dutch to me, I think I mentioned that checking the oil & water levels is about the extent of my mechanical knowledge. Any chance of a picture or a sketch of what I’m looking for? 🙏🏻
Get what you're saying - badge engineered - but TBF, I have to say - it's more than reasonably made Aiden ... probably a lot higher spec. than their own badged tish ... the Germans'd not be happy with tish with their name on it
I'll take you some pix David
make sure you have a tab on every pin David @Tintan28 or they can escape/work their way out with disastrous results
this is the nightmare one to get out .. will only come out in one position with the shell removed from the body
these'll slip out easily (with the bolt removed)
and this is the one that's never had one fitted
Happy Birthday for the other day Graham, glad to see the 801 getting some love.
The floor slides out of that trailer by the way. I've replaced it once already!
cheers Ollie ...
it'll be Lil' Jakes second anniversary of re-locating to Wales next month ..
I've promised him that his winter coat'll be with him soon to celebrate ;) nudge nudge;):)(y)
the floor'll most likely come out easier in bits TBH ...
can then get the channels, etc. cleaned out for an easier refit.
Any memory of what thickness board is in there?
can soon measure it otherwise :rolleyes:
T
Tintan28
Cheers @V8Druid I see the issue now, a picture paints a thousand words! (For divvies like me anyways!)If there is one/any missing on mine presumably I’d have to get something fabricated as I’m unlikely to get them off the shelf??
cheers Ollie ...
Yes, Its in a box in my hallway, ready to go and has been for the last 18 months! Being young I have no idea how the postal system works and I've tried emailing it several times but it never seems to send the attachment.
Do you get deliveroo in your area? 😁
Seriously though, they've changed stamps I found out last week and wont accept ones that don't have a bloody barcode on now! Way to make it awkward post office!
The floor is 18mm pheolenic ply. I got a few sheets off ebay and they haven't lasted 5 years on any of my trailers. Think Ill buy the really expensive stuff next time.
have a look when you can ... I've one to make for mine and wouldn't be a huge feat to knock out a few more if needed ;)... could always post 'em up to you (y)
JerryRtilt
JerryRtilt
I find WhatsApp better for bulkier items😎
will see what the local merchants have, but likely to be eyewatering with any of 'em 'round here :(
did you treat the underside at all?
I like Hermes/Evri ... always been a good service on deliveries and collections (y)
If sending anything over the next few days, hold off if planning to use Tuffnell`s, doesn`t look good, all staff called to a meeting at 12 on Monday.
