have a few Hitachi 9" ... bloody great grinders ... never tried their smaller range ..
the noise/smoke scenario's what did for me Mak 4.5" ... but it had had several years on the bench in the workshop, 'fore it came home, so has seen some seeeeeeerious use ...
TBH you're better off buying decent - once, than cheapo tish ....
remeber Makro ? ... used to do ultra cheapo 4" crap ... but had 3 yr warranty ... used to take 'em back half a dozen at a time for replacements :giggle:
.. every other month :ROFLMAO::ROFLMAO: ...
they got PO-ed with me eventually and started to get arsey ... and I got fed up with pissing about with them .....
think I had my money's worth out of 'em over 18-ish months though:LOL:
Nutool! Still got one somewhere! Sure they were about a tenner?
They were cheap, but definitely felt it compared to a quality brand. They almost felt fukced right out the box! 😂 they did a job, but give them one too many hot suppers and the brush holders would melt iirc and that was your lot……
Gecko
Gecko
... no spanners required ..
On that subject, I just picked up one of these, but haven't had a chance to use it.
any one used one?
Best description I can think of it's like a one wheeled detroit locker. You rotate the outer and it cams the load off like it was never tight.
Have a suspicion it'll work well, but fail quickly
Cyberprog
Cyberprog
any one used one?
Never used one, but they look good.
any one used one?
We had a couple 9" grinders with this style qrn and it was ace. Did last good too
Gecko
Gecko
Thanks, that's promising.
Unfortunately my 9" is the one it's not going to fit. It's the nut that has the alignment spigot, not the rear support like every other grinder.
Hopefully it'll fit in the dish of a 125mm disc- it's a bit chunkier than it looks.
that's the ones :giggle::giggle:
deffo .... we gave them some hammer and they ate brushes too ... but what you expect for a tenner :LOL:
they were cheap tat, that worked for a while ... and with 3 years on 'em had plenty of time to get through loads of 'em ........ and we did :ROFLMAO::ROFLMAO:
Stock
Stock
This is what I use Druid made by Milwaukee, have them on all my grinders..........................................................
Milwaukee MIL352473 Quick Lock Angle Grinder Nut M14 Flange​
Snap👌
Also trying this out:
Ruddy quick and seems solid enough.
Slitting disc might be a tad weaker but not bust one yet.
any one used one?
Have had one on a 9" bosch grinder here probably over 25 year and it's still fine (grinders dead now mind) will be going on the next 9 i buy
Snap👌
I bought a set of those slitting disks accidentally - fortunately they still fit standard grinders!
Never seen one of those before 🤔🤔
It's incredibly quick to switch discs if you doing a lot of slitting .
Weather it will ever catch on in a big way I dunno. It's incredibly similar to the Fein starlock system for multitools.
Can't see the point tbh just extra cost and less choice imho on a 4.5 inch grinder, discs only need be put on hand tight and then you can take them off by hand anyways apart from the v odd jam which might nip discs too tight.
Grinder only about 50quid , I guess it be worth it in busy shop with production style stuff maybe but thought be of interest to the grinders on here.😁
Was good for swapping between flap and slit but I prefer 2...or more grinders
's why I said I wish i'd bought two at 25 quid .. but swap's quick .. never do 'em more than hand nip on /off
pissy wet start to the day yesterday :( .... so used the morning to get a few 'errands' done ...
trip to town for Pam to collect her new glasses ..
and I trolled off to the Doc.s for me prescriptions and down the hospital to get me bloods done ...
they forgot to do 'em when I was down in Caeeeerdiff last and sent me the paperwork to get 'em done locally. Can just walk in to the phlebotomy dept., as long as you have the paperwork :cool: .... place was dead .. usually manic down there.:oops:
Didn't clear up 'til late afternoon so not a lot done yesterday....
apart from a hunt for a tiny screw for Vicki ....
for her over-locker, which she'd 'butchered' getting it out to change a foot ...
got a box of misc. small stuff and having identified what I was after (M2 x 0.4mm x 5mm), I trawled through it and found two suitable candidates, but looking a tad ropey.:(
searched me taps and dies draws and actually found a suitable die to tidy up the two possibles ...
try running a die down a 5mm long, 2mm dia screw :oops::oops: ... jeweler's loupe job!! ....
see how they fit tomorrow, when she comes up with Harper (and the over locker) :rolleyes::) ....
but have found some new ones on Fleabay with a hex socket C/s head, instead of the Philips, that got butchered and ordered a few.(y):giggle:
Today's been a lot better, weather-wise ... dry, with the odd bit of sun and a damned cold S Westerly (unusually cold) blowing hard :( ...
so the MIG was left in the box :( ... did think I was gonna get well and truly pee-ed on about 4 o'clock ... went real black and thought "here it comes" ... but it sailed on by :giggle::cool:
Got a few bits lopped with the band saw first off ..and tacked together ...
set out a few holes ... drilled 'em and captured a few bolts
trial fit .. (y)(y)
and firmed it all up .
then went hunting for a bit of mesh ...
and got that stuck in ..... MIG'd've been handy for that :rolleyes: .... then it was time for .........:LOL:
sit it in spot
and re-attach yon oil cooler
well happy that it went together very well (y) .... had originally planned to park it right on top of the end of the chassis, but although do-able, was gonna leave things very tight for the plumbing, to come, so thought better of it and moved it out those extra 4" :rolleyes:;)
posty arrived mid afternoon with this ..... :giggle:
can get it into the fuel tank tomorrow 'praps, subject to Harper's humour ... and hopefully sort a pick up and return system for the motor to sup motion lotion from it too .... know what I want to do ... just got to make it happen :giggle:
searched me taps and dies draws and actually found a suitable die to tidy up the two possibles ...try running a die down a 5mm long, 2mm dia screw :oops::oops:... jeweler's loupe job!! ....
rude awakening, half seven from Pam ..... "Vicki's got yon rat cornered ... you did say ring when ever" so shot down the village to find she'd locked it in the upper part of her triangular hen coop thing ... had gone up the ramp after eggs and she hauled up the ramp :giggle::giggle:
"You drop the ramp Vicki an' I'll shoot the lil' sod, when he appears" ...... not so much 'fish in a barrel' as trying to down an Exocet with a pea shooter ...... he stopped doing laps for a moment and that was his nemesis ;):)
Got the (not so) little bastard
been trying to get him for weeks ... don't like killing much these days, but a rat's a rat ... end of
fitted the modified screw in the over-locker, which I'd taken with me and came home for some brekky, with Ratus Ratus in a bag, for cremation in the burning bin :giggle:(y)
one list item very firmly ticked off :cool:
