and the third word is OFF Aiden ....Yes folks..... you are all correct.... it would have been easier to weld new brackets on the buckets![]()
At the risk of teaching great grandad to suck eggs, Iโve hole-sawed up to 35 mm plate with bog-ordinary starret hole saws, and my technique is mark it with the saw, then drill a series of 10-12 mm holes round the inside and flood the saw with oil. Gives the swarf somewhere to go and speeds up the cut quite considerably.after researching the 'net for what a B20 hitch ought to look like --- first off was create some 'hooks'
View attachment 55659 View attachment 55660
and a 'latch plate' to attach 'em to
I'd found some Ying Tong seller flogging these and thought for the price (circa a tenner, IIRC) I'd give one a try - 70mm TCT hole saws
worked alright too as long as you took it slow and kept them clear of swarf ...
produced some very respectable 70 mil holes
until the inevitable happened .. but a 20mm Jacobs dealt with the problem
View attachment 55667 View attachment 55668
and I was back in biz ....
got a pair created and tried 'em out for a fit .....
I'd bought some 90mm CDS tube for bosses, that'd sposed to have arrived with a 70mm bore/10mm wall, but'd arrived at 69mm boreand not having a lathe at the time I had to get creative in opening them out, so having lopped off some 20mm bits and attached 'em to the cheek plates, I could open them up with the hole saw .. a side at a time
'til I'd gotten 'em all sorted .. slow, but workable
cool idea Bri .... that was the issue with that 70mm .... a very small curf and nowhere for the swarf to escape ... made for a VERY slow hole ... although I still have the TCT saw I've since acquired a 70mm TCT broach, which flies throughAt the risk of teaching great grandad to suck eggs, Iโve hole-sawed up to 35 mm plate with bog-ordinary starret hole saws, and my technique is mark it with the saw, then drill a series of 10-12 mm holes round the inside and flood the saw with oil. Gives the swarf somewhere to go and speeds up the cut quite considerably.
Also, can you break these posts up a bit, just to make it easier for us to criticise?![]()
well when I say delivered ... I met Paul in a lay by down the road for a trans-ship into me trailer - as would become a bit of a norm, as he can't get ALL of his truck in here - just the front halfso what's next ?????? .........
..... another cheap ebay acquisition, delivered by our own forum transport dept.![]()
IIRC I gave a hundred quid for the whole thing and a bit more than that to Mog for the tranny
cheers Bri ..... may have been, but more likely to have been either Wurth's 6013s or Wolfram 6013 from Essco's locally ... cheap rods, but weld really wellFincord M? Tidy welding, Gra.
yeh - sorry Mog .. CEF -ers will have .... lots won't thoughI have seen it all beforebut fair play to make something from nothing
as for my pals scrap yard where do you think the โnew roller doorโ came from
Lots of things have changed for us all since CEF. Back then I'd not of thought I would be where I am today.yeh - sorry Mog .. CEF -ers will have .... lots won't though![]()
