create your own Att.s, etc. ... tales from the Druid's workbench
after researching the 'net for what a B20 hitch ought to look like --- first off was create some 'hooks'
View attachment 55659 View attachment 55660
and a 'latch plate' to attach 'em to
I'd found some Ying Tong seller flogging these and thought for the price (circa a tenner, IIRC) I'd give one a try - 70mm TCT hole saws
worked alright too as long as you took it slow and kept them clear of swarf ...
produced some very respectable 70 mil holes
until the inevitable happened .. but a 20mm Jacobs dealt with the problem
View attachment 55667 View attachment 55668
and I was back in biz ....
got a pair created and tried 'em out for a fit .....
I'd bought some 90mm CDS tube for bosses, that'd sposed to have arrived with a 70mm bore/10mm wall, but'd arrived at 69mm bore :mad: and not having a lathe at the time I had to get creative in opening them out, so having lopped off some 20mm bits and attached 'em to the cheek plates, I could open them up with the hole saw .. a side at a time
'til I'd gotten 'em all sorted .. slow, but workable
At the risk of teaching great grandad to suck eggs, Iโ€™ve hole-sawed up to 35 mm plate with bog-ordinary starret hole saws, and my technique is mark it with the saw, then drill a series of 10-12 mm holes round the inside and flood the saw with oil. Gives the swarf somewhere to go and speeds up the cut quite considerably.
Also, can you break these posts up a bit, just to make it easier for us to criticise?:)
cool idea Bri .... that was the issue with that 70mm .... a very small curf and nowhere for the swarf to escape ... made for a VERY slow hole ... although I still have the TCT saw I've since acquired a 70mm TCT broach, which flies through :giggle: ... especially with the Ajax turret powering it
plus you get some nice re-usable slugs, with just the saw / broach
as for the request -- LOL :ROFLMAO: ... Happy New Year to you mate
trouble with splitting 'em is once I find the pix, I'm then trying to maintain a continuity .... some of 'em are months apart :rolleyes::oops:
I can try and split 'em down a bit .... not sure what'll be up next .. a few of 'em are 'well documented' - pix-wise ;):giggle:
so what's next ??????
I originally quickly knocked up a beam for the back end of JakieB from a lump I had sat in my yard
and having acquired the 'Drema, wanted to use it on there for spreading some planings about ... had other plans for it ultimately, so came up with a 'quick fix' for some 'pro tem' usage ;)
so lopped the cheeks off that'd been cobbled for the Jake and set about attaching summat a bit bigger
with a few bolts to keep it put
the eagle eyed'll have spotted the 17mil holes in previous posts on the b20 adaptor - and now you know what they were for ....
it worked a treat and got me a usable beam to speed up some spreading about
the red/pinky bit in the background played quite a role in some up and coming bits an' bobs ........ another cheap ebay acquisition, delivered by our own forum transport dept. :giggle:(y)
short enough @Bri963 ;):):giggle:(y)
so what's next ?????? .........
well when I say delivered ... I met Paul in a lay by down the road for a trans-ship into me trailer - as would become a bit of a norm, as he can't get ALL of his truck in here - just the front half :rolleyes::giggle: ...
he'd picked this up for me 'en route' elsewhere and made a small diversion to meet me with this 'bit of a lump' :rolleyes: ...
again ..
tranny cost more than I paid for said 'lump' :ROFLMAO: ....
but was a nice pile of 'goodies' aside from the Steinweg brick/block grab, it came with a rotator and 6 x 2 diverter, plus a pile of 'useful' carrier framework :giggle: and loads of useful fittings/bits an' bobs :cool:
2015-01-06 16.14.13.jpg 2015-01-06 16.15.16.jpg 2015-01-06 16.16.06.jpg 2015-01-06 16.14.46.jpg 2015-01-08 15.31.20.jpg 2015-01-08 15.33.41.jpg 2015-01-08 15.34.22.jpg
next up was a bit of a dis-assembly job
2015-01-24 14.52.52.jpg 2015-01-24 15.37.30.jpg 2015-01-24 15.37.41.jpg 2015-01-24 16.39.58.jpg 2015-01-24 16.39.49.jpg 2015-01-24 16.52.02.jpg 2015-01-24 16.52.19.jpg IIRC I gave a hundred quid for the whole thing and a bit more than that to Mog for the tranny
but what ????? .............
wanted to retain the ability to pin the rotator back on ... and attach otherwise
stitched in place and a a few gussets inserted
flipped to consolidate the underside
and no ------- didn't borrow Rory's camera for this one :giggle: ... poor light at a guess or a bit of hand shake
and fully consolidated for a bit of fettling
next up --- a.n.other sun dial :giggle::giggle:
and here's what the gas axe was out for .... the dozen holes gave me multiple orientation options
then it was 'stick time' ... few tacks ..
and some braces
then nail it together time
few trial fits .......
and some 'shiny'/not so 'shiny' ..... ... also took some scallops out for Aux QC plumbing under the VA-r
then a few more bits to do .....
went down me mate's place down the road, to use his bandsaw (hadn't bought my Meba at this point)
and lopped a few blanks .........
opened 'em up again using the previously tried method with the hole saw, using an existing hole as a guide ... as said - slow but successful
a few additional holes in the beam whilst I had the mag drill out
then dropped it on the Steinweg :)
ready for the next part of the operation :rolleyes:;)
some of you may know/recall that as the 'Drema spent its life in waterworks, 'fore I owned her, she runs Fuchs Plantohyd 46 Bio-oil ...
consequently, anything I buy with a 'hydraulic history' needs purging, 'fore getting connected to the 'Drema ...
apparently the contamination limit is 1% and as the 'Drema carries 180L in the tank and probably another 50-70L in the system it doesn't take a lot to account for 1% contamination:oops:
so everything gets blown out with 150psi in all directions, several times, 'til I'm not collecting any more in catch bottles/buckets ....
at which point I consider it as safe as it'll get to introduce said att. to the system
and give it some oil for a test drive
this 'un functioned just fine ..... and has quite a grip
picks up packs of 9" hollows sweet as a nut :)(y)
next up ......
my favourite Geith bucket ......
bought from a guy reasonably locally ....
had a very similar disease to mine, when I got chatting with him - also bought my ped. roller off him - sadly died a few years ago - we kept in touch ...
he had a small plant yard in Aberdare.
arrived with 55mm pins but centres too short to open up to 70s and cheeks too narrow by 10mm :( so needed some major mod.s... a nice bucket though
so ....
set about it with the gas axe
WP_20150326_15_36_54_Pro.jpg WP_20150326_15_37_06_Pro.jpg WP_20150326_15_43_48_Pro.jpg WP_20150326_16_13_36_Pro.jpg WP_20150326_16_14_01_Pro.jpg WP_20150326_16_26_40_Pro.jpg WP_20150326_16_26_49_Pro.jpg
and having de-cheeked it ....
it got a new set
Mr Ying Tong's hole saw still doing sterling service
but starting to show a few signs of 'use' ... holes weren't as 'clean' as they were and it'd lost the odd tooth
and then it started giving grief in the 'drive' dept. ..
didn't want to wreck the Jacobs, so an alternate got devised ...
and welded a MT sleeve to the saw ...
and used one of my QR MT drive chucks to run it ... very handy tools .. just mount whatever in the multiple carriers I have and they're all quick release to change over :cool: ...
even handier in a lathe tailstock
got the job done anyway ..
trial size up
looked OK in the morning after, so 'twas boss time ..
set them up flat on the bench and .....
gapped and braced it all ...
and transferred it to the bucket ...
and tacked 'em in place
fore adding a few gussets
and starting to nail it all together
Fincord M? Tidy welding, Gra.
cheers Bri ..... may have been, but more likely to have been either Wurth's 6013s or Wolfram 6013 from Essco's locally ... cheap rods, but weld really well (y) (at least they were flogging 'em cheap?) :rolleyes:
so - all nailed up
and hung on the Miller for a trial
then - a bit controversial on CEF but the teeth came off ... wanted an edged bucket
and they could always go back on
and a coat of HBZP grey
and a bit of use .... which turned into a hell of a lot of use - as said - my favourite bucket
legs down for levelling up :rolleyes: ..........
had gotten well used to working FOW by this point ....
in fact it's odd not to rock around a bit when you have the stab.s down :unsure::giggle:
and according to the date stamps on the pix ... this came next ;)
but 'praps not ..... having looked further into the folder ...... :unsure::rolleyes:
remember seeing this ?
well after introducing it to the mighty gas axe ......
after a considerable amount of thought and planning ..
and then some careful trimming ..
ended up with several 'components' ..
and a few extraneous bits
some of the 'components were going to need some 'cleaning up' ...
can't beat a good wedge for separating things
and a good toe jack, with some packers .... after the grinder's had a go, of course
one down ... clean up all the crud and trim as required
#2 ....
they came off way better than expected
clean trim and prep ready for the next bit
off cuts :giggle: ...
hate waste :rolleyes:
planning is 9/10ths of the job ;) .... plus measuring twice/thrice - cutting once :giggle:(y)
bit of thought and it's quite remarkable what you can create form next to now't ....
our Mog's the epitome of that philosophy (y)
but he does have QUITE a toy store to 'shop' in ..... or did have, anyway :rolleyes::cry::cry:
so pile of sundry bits ... looks a bit wet :oops:
suss the next bit with one part clamped in spot .... then tack a few of the sundries in place
ready for a load more
and a lot of consolidating ......... for a trial fit
looked OK
so create the second one and back to the bench
nail a couple of not long enough bits together to make one 'long enough' :giggle: ... nail it in spot and give it a try - again
all cool .. consolidate it
more bits shown the gas axe and ready for a clean up with the disc
and dropped into spot on packers to get the alignment and clearances right
'fore tacking it all up and lifting back into spot to make sure all was well ...... 'fore going for it
happy Druid :giggle:;)(y)fitted as planned
and ..
could drop them on the floor and drive away ...
or pick them off the floor with the blade
back to the bench to get it all nailed up solid
and add a few more gussets
and add a lot more hot stick
fore doing the usual ...HBZP grey oxide, followed by .....
:giggle::giggle:
these have come in very handy .... and have also been subsequently mod.ed / had an att. made for them for the VA-r's use too
that block grab's carrier frame work came in real handy ;):giggle:
so did the rest of it .......................
I have seen it all before๐Ÿ˜‚ but fair play to make something from nothing๐Ÿ‘ as for my pals scrap yard where do you think the โ€œnew roller doorโ€ came from๐Ÿ˜‚๐Ÿ˜‚
yeh - sorry Mog .. CEF -ers will have .... lots won't though :rolleyes:
