honey_badger
Got the bandsaw running last night, great to see it running.
That chink in the female cup is creating a clunk on lower speeds, I'll have to try fix that soon.
The cut wasn't straight, have to get it lined up properly, see if I can't work out how to do it. Suds should be here on tuesday which will be good.
Then started stripping the lower cylinder today, very glad I did that, it was a bit variable on the way down, found out why...
Draining a mixture of sludge and water out of it... Possibly sludge and coolant in the best case scenario.
Someones had a go at the bottom of the rod before...
Might explain some of the slag like particulates floating around in the liquid
Cleaned up the inside with a few swills of petrol, dried it all out, now the question is what oil to put back in? Says Energol HL 100, which from some reasearch is equivalent to ISO46 or sae30, or can I just bung standard hyraulic/transmission oil in for the tractors and diggers lol.
Edit -
Mine is different to the one on the parts website, its got a spring inside for starters...!
So maybe a seal kit wouldn't be the right one?
Edit -
