Auction watch
The RS cos worth keep going up sold for 132k.
@V8Druid nice vitesse there for you
's a peach ...... and one of the homologation run of 200-ish twin plenums .. very rare indeed... would love to know how many survive ....... BTCC winners for several years :giggle: .. then Tony Pond went rallying 'em with decent success
I recall reading somewhere a little while back than some brit team had won an event at Le Mans 24hr with an SD1 team this year, presumably touring/saloon car category?:unsure: .. they're a formidable bus, go well and handle very well for 1500+kgs of motor
plenum flexis are 'scabby as', as is the under-screen trim edge, in the usual place :( ..... fuel filter's in the wrong place too
and flipping the rear most diff to get rotation right ...... 's a cool solution :cool:
But that would be like driving in reverse all the time on the rear diff🤔 not really made for that as the thrust will be on the wrong side of the gear teeth🤔🤔
I think the bigger problem would be no diff between axles.
think about it Mog .. the pinion coming out the back of the 1st axle will be contra-rotating, so the rear one needs to do the same - agree on the thrust :unsure: -- I think :unsure:
Could put a slip clutch on the rear axle, like on a tractor implement PTO?
Think you would be better off fitting air suspension and putting more pressure on one axle. Then when your stuck you can give it full wack. Would also give a better turning circle and save tyre wear.
Was watching these but then got drag out by mrs for coffee with little one, would have liked that hinowa and ausa mini forklift. Prices are down though.
Refreshingly realistic prices
Kubota 8 ton 20k, they’re coming down fast, tb175 9k hours made £8k
Kubota kx161 was blue smoking a lot though
When to a hauiler retirement auction last week, trailers still very strong money, fresh stuff many 1000s more than new, couple of year old trucks down a little, 3-6 year old still about the same, a bit older strong money.
