5/6 tonners
Looking at 5/6 tonner excavators for site work. Looked at a tidy U55-4 local. Any others I should look for or steer clear off ?
i think all the 55 series are the same pumps/engine ?
Certainly not my favourite there very lively on the leavers I'd much prefer a Kubota or a wacker
I thought you were getting a KX-57 with full-fat Engcon S45 setup earlier this year?
I’d personally avoid a zero tailswing as it will be compromised stability-wise. None of these little machines have much of an arse on them.
KX57 or TB260 would be where I’d be looking personally.
jd6820
jd6820
Yeah think my choices would all be conventional tail swing...
Kubota KX057-4 or KX060-5
Volvo EC55D
Takeuchi TB260
The only exception I'd have for the reduced tail job is the Hitachi ZX65USB as @CPS says a great machine, smooth to drive and quite stable.
bit old and too many hours. looking 4 years old and sub 2k hours
See if JR Leach still has some of the hitachi stuff in stock!!
Out of interest would you not be better going 8 ton as haulage is the same.
If you have your capable 3 ton already, then likely the 5 ton will be used for bulkier digs in which case must as well have 8ton? I have a 3 and 5 ton, but would prefer a 3t and 8t to cover covers all bases better... 5 is still too small sometimes.
Big price difference though. I think that's why 6 tonners are so popular and most are specced with 8 tonner buckets so people think they'll get a similar amount of work done with one (but they wont).
For sure, But if buying used, the price difference seems to come down quite a bit...
Left hooker
Left hooker
Got a 3 and a 5 ton and 3 don't get used much at all as 5 has tilty and does 3 ton work and also up to 8 ton work
