Mate of mine did that with a boat motor but filed just a little too much off the throttle stop so it used to run a bit too hot 😁
My first bike on the road was a C100 Cub ... Hodna 50 to the uninitiated ... stepthru 3 sp auto ... was a great little thing ACY 533B .... yeh '64 ... took 3mm off the top of the slide and would do 55 mph .... which for one of them was like fitting NOS (N2O) :giggle::giggle::giggle:
forgot to say .... operating takes a little getting used to .. especially if you'm a bike rider ... the more you squeeze the faster you go .. counter intuitive, when tou're heading for trouble ..... automatic reaction is to squeeze (the brakes) - there aren't any .. let go and the hydro stops it dead .. squeeze and you'm off like a scalded cat
just takes a while to overcome the instinct
Boss bought a rough terrain walk behind mower. Basically a smaller version of your Dane but without the footplate and no steering function. Had a a gearbox and we all repeatedly told him clutch was squeeze to go. So he decided to take it for a spin. He started it up and then yanked the gear lever straight into top gear the clutch engaged. The mower took off and sent him flying. The handles got yanked out his hands,the mower stopped but he didn't and went piling straight into the back of it. Infront of a dozen staff members
as said ... the go pedal/lever is totally counter-intuitive ... 'til your head gets itself around it, you're squeezing like **** trying to get it to slow down :oops: .... usually heading for disaster :ROFLMAO::ROFLMAO:
Left hooker
Left hooker
How do you thing I managed when I picked them up for you using one for first time and using live one to drag dead one up onto my beaver tail lorry 😂😂🤣
yeh .. bet it was interesting viewing :ROFLMAO: .... expect your head board cringed at the sight of you hurtling up the bed at it ... good job you had a bit of an anchor :giggle:
Left hooker
Left hooker
That was my issue anchor was grounding out and it was raining so ramps were wet
L
LKSF
Pennine Hillbilly
But as it hasn't got the oil cooler it'll run too hot. So it'll put out plenty of power, just not for very long.
L
LKSF
Pennine Hillbilly
As kids we had C70s for field bikes, amazing how reliable they were for the amount of abuse they got.
Eight years ago today, these came home ... was a busy morning :giggle: .... ready to load at 08.00
first one successfully negotiated round some tight corners .. 40ft box - 28ft trailer :giggle: over fly the tight bits
and off
the inimitable Russel
last one taking flight .....
..... and in .........time for a well earned lunch
finished by 13.00:giggle: ...... went like clockwork (y)
trying to decide today whether yon Deutz is 12 or 24v .... everything that came with it/off it's donor was 12v so thought I'd give the Mog a call and see if he could remember .... he couldn't for sure and suggested a gander at the starter, which i'd already considered and a tel.con. with Paul had seemed an easier first option :rolleyes:
so a gander it was .... after eyeballing the alternator first ....:rolleyes:
WP_20220504_13_05_21_Pro.jpg followed by the glow plug timer relay WP_20220504_13_06_24_Pro.jpg
and then the starter, WP_20220504_13_11_41_Pro.jpg which lives behind the air ducting WP_20220504_13_11_36_Pro.jpg sadly the numbers're not visible and I sure as **** was not taking it off to confirm what I was pretty sure I knew already .... Mog was fairly sure it was 12v, but couldn't be positive.
the reasoning behind all this was that i wanted to make it a battery carrier frame ... and decide WTF to put it ... here was my favorite spot ....
for a large lump of Varta's finest and still leave room for a second alongside if needed (which i hope it ain't - one's dear enough!!)
wanted to get this sorted as I had sussed everything else i need to create for this and wanted to pull it to bits to firm the chassis up ....
motor out/off ...
and relocated to a temporary home for a while ...
followed by the oil tank ... had to lean it against summat for a while ... :rolleyes::)
:giggle::giggle:
leaving me with ... ;)
so I could flip it around a bit for consolidating it :giggle:(y)
cleaning it all up and ...... you know .... the usual ....
coat or three of shiny tish ... get the motor back onto it tomorrow ..... after I've had use of the full bench top, to lop up a sheet of CR4, to create a fuel tank .. having sussed how/where to put it and still have space for the not insignificant air filter (read that as 'kin large ) :oops:
frustrating day ... wasn't able to get out 'til gone eleven, sorting paperwork for 'the boss' ... boots on - about to go out the door and a truck pulls up outside ... " WTF is this? " looked at the driver and it's John, the guy who used to own our place, the farm and worked it all ... emigrated to Oz in the late 80,s and always calls to see us when he's over .... had only been talking about him yesterday, when Pam'd been told he was thinking about coming over to see his 95 yr old mother. Damn me he's here!! :LOL:
so that ****ed a couple of hours ... but nice to see him and his daughter
He'd not been gone ten minutes and Pam's sister and her hubby arrived ... three of 'em off to a funeral at 2.45 .. I opted out o' that one ... last three in the local church have produced 30 odd cases of covid each time .. so sod that!!
So was 2.30 by the time I got to me bench and stuck the subframe/chassis on the deck, out me way
so's I could have the bench .... hauled this out the box ....
and onto the bench .... just about creased me getting the damned thing in there when it was delivered ... could used to chuck these about, nae bother - getting old :(
the makings of a fuel tank ... 2.5m x 1.25m x 3mm CR4 .. no mill scale :giggle: .... had already sorted the design and nesting, so set about it with a thin disc ... didn't want to plasma it .. and risk distortion
between the 'funeral party's' return .. more socialising ... and general faffing, was gone tea time by the time I'd finished creating the flat pack
Oh for my guillo ... ten minutes tops to knock them out :(:cry:
all de-burred and stashed indoors ready for assembly tomorrow, after a couple of flange plates and mounts to cut and make up
Paul the Hermes guy'd arrived, whilst I'd been with the SIL/BIL, after they'd gotten back, with this ..
(commentary in the "what did you buy today" thread) and having found the door wide open, as it was so warm(ish) here today, proceeded to tell me about the elderly lady who lives close to the top of our drive, who was the victim of a 'distraction burglary', Bank holiday Monday ..
had been out gardening, when some guy had come into the garden supposedly asking directions, whilst his mate had presumably been in her place, relieving her of her valuables (jewelry/money) ... one of several that day in the area.:mad:
we'd been to town that day for eye tests and a bit of a supermarket foray ... had gotten back maybe 2.5 hrs later to find a large pile of pretty fresh dog tish on the lawn .... o_O:censored:
there are no dogs here (or any footpaths/public ROWs) and I'd been puzzling this the last couple of days ...
assuming we'd had 'visitors' whilst out ... :rolleyes:
looks like we may have had a close call, perhaps? :unsure: but all is always as secure as it can be when we're not here (short of a few laser cannons :giggle::giggle:)
As I have said before .... want balls to wander down here, to an unknown reception ... and I wouldn't hesitate to deal with scum bags severely:mad: .. always got plenty to hand to use ;)
Anyway .... assuming the forecast is to believed ... will get said tank assembled hopefully and mounted tomorrow:)(y)
Cyberprog
Cyberprog
View attachment 35073View attachment 35080
so's I could have the bench .... hailed this out the box ....
Paul the Hermes guy'd arrived whilst I'd been with the SIL/BIL after they'd gotten back with this ..
I'd suggest a couple of cloud cameras but your internet is shite enough without adding to the load...
