T
Tacitus
That seems to be a good compressor, made in OZ apparently.bought one of these a while ago .... but mine is red .... makes a big difference in performance
View attachment 29059Wolf Dakota 100 Air Compressor 3HP 14CFM 230V Twin Cylinder 10BAR 150psi Belt Driven : Amazon.co.uk: DIY & Tools
Free delivery and returns on all eligible orders. Shop Wolf Dakota 100 Air Compressor 3HP 14CFM 230V Twin Cylinder 10BAR 150psi Belt Driven.www.amazon.co.uk
was just over 200 quid when I pressed the trigger ......
has been very good for all my air requirements ...
tyres, die grinder, blaster, etc. 90 ltr tank and very often plug my air bottle in too, if i want a bigger reservoir (30+ ltr ex-propane bottle) and also have 47kg bottle I use for air too, if that's not enough .. again just plug it in and tandem them up
The original post talked about choosing a direct drive. DD are light and portable but extremely noisy and the CFM is marginal, good for nail guns or pump up tyres.
Belt driven are slower and use bigger pumps.
One thing I observed is that compressor suppliers, quote the free to air performance of a compressor with some free poetic license.
The table that list the CFM requirements of a tool don't help either.
The free to air volume quoted by manufacturers, is taken from the volume of the pump and the revs it spins. Rather deceiving since the resistance of the compression is not taken into account. From experience, if you need 10 CFM for a tool, make sure your compressor can deliver at least 50% more. Worse tools for air consumption are grinders and spray paint guns. Tyres can be pumped up with just about any hobby compressor if you have time to wait ... don't advocate to pump up your tractor rear tyre with a 4wd 12v compressor, but it is theoretically possible.
Good quality compressor manufacturers, have a hard time competing with the chinese onslaught, exception perhaps the Italians. Chinese compressor pumps are everywhere and their quality is variable to put it mildly. Italian pumps are better.
With compressors that are not intended to be portable, bigger is better, and watch the power supply. Compressor motors don't do well with power restrictions. a supply cable that is 4 mm2 for single phase 240V would be ideal.
As for the popular wisdom that says don't use an extension ... well ... yes, if you buy your extension at Kmart.
An extension is just more cable. The workshop or house cabling can be very long depending how it is built. So, if you have a short extension with properly rated cable, plugged in the powerpoint your electrician built in the main switch board, is not the same than having a 30 meter long extension with 1mm2 cable plugged in your bedroom powerpoint.
I run a 280 amp MIG welder off a 20 meter extension with no problems at all. I built the extension with industrial 32A plugs and 6 mm2 rubber insulated cable. The mig itself has a 10 meter 6 mm2 lead.
